265/65/17 vs 265/70/17 Fit
Discussion in 'Wheels & Tires' started by sts167, Jun 2, 2010.
  1. Jun 2, 2010 at 7:21 AM
    sts167
    sts167 [OP] Well-Known Member
    Will 265/65/17, 265/70/17 fit on my '09 4x4 SR5 that came with 245/75/16 tires? Have everything all lined up, just need to pick a tire size. Suggestions welcome.
  2. Jun 2, 2010 at 9:17 AM
    crazybayman
    crazybayman Oh 'eah
    Newfoundland
    09 4x4 4.0L V6 Access Cab Standard
    AutoStart, Sirius Satellite Radio, 16x8 Moto Metal 955s, 265/75/16 Duratracs, Fog Lights, Skid plate
    Yes, they will fit.
    However there is a chance that the 265/70/17s may rub your mudflaps when in the fully turned position, depending on the rims' offset.
  3. Jun 2, 2010 at 9:20 AM
    sts167
    I will be running on stock 17" TRD rims... not sure what the offset is on those.
  4. Jun 2, 2010 at 10:02 AM
    tuckr2
    tuckr2 Well-Known Member
    Western Washington State
    2010 Silver dbl cab LB 4x4 It's Purdy too!
    LT265/70/17 BFG A/T's, Disabled Seat Belt Buzzer, Black and Gray Covercraft Seat Covers front and rear, Matching SnugTop Supersport Canopy, undercoat, bed mat, window vent shades. Black Weathertech Liners. Trans TSB, Rear Spring TSB Installed.
    General Grabber AT2 or Yokohama Geolander A/TS. Both good tires for general on/off road.
    Present experience with the Yokohama works great in wet conditions, handles well in black ice conditions, very well in light mud and trails. A good handling, quiet tire on the road. Seems to hold up pretty well long term as I have about 20,000k with minimal wear.
    As to the General Grabber I don't have quite the experience but do have a buddy who swears by them. Although they are just slightly more noisy on road. They do have deep cleats and wear great. Both tires are very well priced compared to some others. Check out The Tire Rack for more info on either.
    Just my thoughts. Ken
  5. Jun 2, 2010 at 11:12 AM
    crazybayman
    crazybayman Oh 'eah
    Newfoundland
    you should be good with 265/70/17...again it depends on offset, and rim width
