265/65-17 vs. 265/70-17
Discussion in 'Wheels & Tires' started by thor2, Feb 21, 2009.
  1. Feb 21, 2009 at 8:44 AM
    thor2
    thor2 [OP] New Member
    Hello all,
    I am a new owner of a '09 pre runner with steelies. I got a hold of the 17" trd wheels which are normally fitted with 265/65-17s. I was wondering on the opinions of people who have put 70's on instead. Ride, comfort, handling. Also wanted to make sure there are no problems with rubbing, I know it is about an inch in height difference. Thanks for any help in my descision.
  2. Feb 21, 2009 at 8:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Being as the 70 series has a taller sidwall, it will have a beter ride. More compliant.
  3. Feb 21, 2009 at 1:37 PM
    thor2
    Are there any rubbing issues?
  4. Feb 21, 2009 at 1:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Shouldnt be. The tires are the same width, and only going up 1" in height. You should be good.
  5. Feb 21, 2009 at 2:00 PM
    RoyB
    RoyB Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    i changed from 65s to 70s. pluses are more aggressive look, more tread on the road. minus is reduced gas mileage. no issues though.
  6. Mar 6, 2009 at 7:57 AM
    paquun
    paquun paquun
    calexico ca
    4x4 tacoma
    How much loss of miles. I did that swap to 70s and getting 14mpg is it normal. what tire pressure should I be running at ?
  7. Mar 6, 2009 at 9:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Add 3.4% to the milage from your ODO, then divide by the gallons consumed. Us ethe Chalk method to determine propper tire pressure.
  8. Mar 6, 2009 at 11:57 AM
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    with the taller tire my odo is about a mile off every 25 miles now. However, my speedo is dead-on compared to the gps.
  9. Mar 6, 2009 at 11:59 AM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    run em at 35psi
