265/65R17 E Rated tires
Discussion in 'Wheels & Tires' started by TRDsport253, Jul 3, 2010.
  1. Jul 3, 2010 at 12:46 AM
    TRDsport253
    TRDsport253 [OP] Well-Known Member
    Fife, Wa
    05 PreRunner TRDsport
    TRD Cold air TRD Cat-back
    Anyone running 265/65R17 E rated? Will I be making a mistake if I go with the bfg all-terrain in that rating and size. They will be wrapping on some 17" konig countersteer type x. How much of a ride different will I feel from the stock bridgestone duelers?
  2. Jul 3, 2010 at 1:02 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    It'll feel like a full sized for a ride. Bye bye plush, hello bone jarring ride.
    I have damn near same size, same tires.
    Plus side is these tires be fucking armoured.
  3. Jul 3, 2010 at 2:23 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    C rating would be my choice.
  4. Jul 3, 2010 at 2:32 PM
    cdmason23435
    cdmason23435 Member
    TRD Offroad 4x4
    SuperSprings, DRL mod, iPOD add-on and a bug deflector that adds at least .001 HP
    I've got load range "D" LT 265/70/R-16's on my '06. Wanted a stiff side wall for towing and I got it. Like Krazie SJ said "bye bye plush ride" but after all it is a truck. :)
  5. Jul 3, 2010 at 7:50 PM
    TRDsport253
    Fife, Wa
    Yeah I want to go with c range but then I would have to go with 265/70R17. But I'm trying to stick with 265/65R17 and those are only available in e range for bfgs at
  6. Jul 3, 2010 at 7:59 PM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    I have E. Rated km2 and they ride fine. A little ruff but it is a truck. They are also heavy. That is the only bad part
  7. Jul 3, 2010 at 8:18 PM
    TRDsport253
    Fife, Wa
    I hear on here there will be issues if you put that size on aftermarket wheels and I know they will be fine on stock sport rims but I'm getting tires for 17" konig countersteer type x. And no lift that's why I'm sticking to the stock size I just really like the look and tread design on the bfg at.
  8. Aug 27, 2010 at 12:18 PM
    TRDsport253
    Fife, Wa
    have anyone else gotten the bf goodrich all-terrain in 265/65r17?
  9. Aug 27, 2010 at 4:14 PM
    Archangel
    Archangel Discount Tire Company
    Charlotte, NC
    13 Malibu LT
    OK, let me be of some assistance. What's the offset and width of the Konigs? The BFG AT in 265/70/17 will give you NO rub issues what-so-ever on the 17" Konigs, provided the proper width (not 9") with proper offset. I'm running the 265/70/17 Load Range C, with no rub issues on a 7.5" wheel with a 15mm offset
  10. Aug 27, 2010 at 4:19 PM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    I am running 265/70/17 on 8 wide 4.5 bs wheels, they rub on the front of the fender liner, that little bump piece at the lower front and only on the drivers side.
  11. Aug 28, 2010 at 2:33 AM
    TRDsport253
    Fife, Wa
    here are the wheel spec:17x8 COUNTERSTEER OFFROAD X
    COLOR: Matte Black
    OFFSET: -10
    PCD: 6x139.7
  12. Aug 28, 2010 at 2:45 AM
    Archangel
    Charlotte, NC
    13 Malibu LT
    Your offset and width are fine. You should be able to run a 265/70/17 without a problem. But if you do rub, it would be due to the offset being a little too low. I would go for as close to a zero offset as you can. Hope this helps and good luck
