265/70/16 Ridge Grappler
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VonStueckle, Mar 29, 2019.
  1. May 24, 2019 at 9:11 PM
    VonStueckle
    VonStueckle [OP] Well-Known Member
    Nathan
    Liberty Lake, WA
    21 TRDOR Super White 6MT
    4R TRD Pro rims, 265/70/17 ridge grapplers
    Just ordered from tirebuyer.com today. 265/70/17 115T 678.04 shipped to an installer after 10% off coupon. Should have them at the shop in 1-3 days it said.
    THE_KiRRAx likes this.
  2. May 28, 2019 at 11:51 AM
    phatfisher
    phatfisher Member
    2018 Cement Tacoma TRD Off-Road
    Any updates on how the 265/75/16's or 265/70's in c load are wearing? mileage? thread wear?
  3. May 28, 2019 at 11:57 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Always go bigger.
  4. May 28, 2019 at 11:58 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I ended up going with wildpeaks. 265-70
  5. May 28, 2019 at 12:03 PM
    09 Redneck
    09 Redneck Well-Known Member
    Ga
    Looks like the new 265/70/17 - 115T weigh in around 44 lbs. From Nittos website.
  6. May 28, 2019 at 12:47 PM
    VonStueckle
    Nathan
    Liberty Lake, WA
    Yeah figured that was a weight gain that was acceptable for me. Didn’t want to add 12-15 lbs per tire like some of the heavier rated tires
    09 Redneck likes this.
  7. May 28, 2019 at 12:48 PM
    VonStueckle
    Nathan
    Liberty Lake, WA
    Just scheduled installation for Thursday so we’ll see how they feel/look/ride after that
    gilligoon and YMMPRO like this.
  8. May 28, 2019 at 12:54 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    These are great tires. Anyone who is getting them will be happy.
  9. May 30, 2019 at 5:56 AM
    VonStueckle
    Nathan
    Liberty Lake, WA
    2EC15E9F-3928-4C12-9100-39198AC83BDF.jpg All loaded up and ready to go
  10. May 30, 2019 at 1:20 PM
    VonStueckle
    Nathan
    Liberty Lake, WA
    75A2CB37-3DF6-443B-8795-3E913294ABF1.jpg 6BF08C82-988E-49AC-B36E-52080C403FD8.jpg
    Before and after.
    Here’s my attempt at an initial review:
    Looks: Freaking awesome. I think (and I may be biased) that this is the best looking wheel/tire combo available for the white Tacomas. With the additional offset and slightly larger tires it just gives the truck a much better stance.
    Feel on the road: Only have about 10-12 mixed miles, but both city and highway feel was great, better than stock for sure. Not sure if it is the larger tire or softer tire material, but didn’t seem like bumps were as bad on highway. Felt amazing driving, no pull either direction.
    Noise: Only time I noticed any more tire noise than stock was while turning sharply, and that could just be due to the new rubber. Highway noise no different from stock, couldn’t hear any tire hum over the road/wind noise of driving.
    Rubbing: None that I have seen or felt yet, did go through a dirt exit from rear of a gas station that allows for pretty good flex of suspension. Tried to turn to full lock while driving through. Didn’t feel anything rubbing. I also have removed mud flaps some time ago so it may rub if I still had those on the front, I don’t know.
    MPGs: Too short of trial period at this time, but didn’t seem to be off much if at all. Will update later when I have more data
    Power/braking: From what I could tell, did not feel any different from stock for power from take off. No change at highway speed for passing either. Braking maybe just a slight difference on getting truck to slow down, also will need more data from driving more miles.
    Wet traction/off road: No data for either at this time. Didn’t have any wet roads today and I don’t really off road much, just light dirt trails occasionally.
    Overall: Very impressed so far, don’t have any negatives so far. In my opinion, these are the best tires for getting a nice aggressive look without getting that MT hum while driving.
  11. May 30, 2019 at 1:28 PM
    YMMPRO
    YMMPRO Well-Known Member
    Northern Alberta, Canada
    2018 Super White Tacoma Pro
    TRD Intake / Falken Wildpeak AT3W
    Looks awesome , thanks for the info!
  12. May 30, 2019 at 2:05 PM
    jareebz
    jareebz Well-Known Member
    TX
    2019 TRDOR DCLB
    Discount tire says 54lbs. Wonder which one has the typo.
  13. May 30, 2019 at 3:20 PM
    09 Redneck
    Ga
  14. May 30, 2019 at 3:33 PM
    jareebz
    TX
    2019 TRDOR DCLB
    I sent them a pm and got this response so looks like Nitto’s numbers are probably correct
    “I'm showing the same numbers that you are on my end as well. Unfortunately we do not have inventory available for the 115T version that we can actually weigh so I reached out to Nitto and they stated the weight at 43.65 lbs. I took a peak at some other tire weights in the standard load construction and they are all around the 40 lbs. mark so I'd venture to say that the weight Nitto has supplied is correct.“
    09 Redneck and Discount Tire like this.
  15. Jun 3, 2019 at 5:24 AM
    #35
    VonStueckle
    Nathan
    Liberty Lake, WA
    I know when I looked on nitto's website when they first released the tires, it said 54 pounds, but then a few days later it was adjusted to the 43.65 lbs. I think discount got their data from the initial info from nitto and didn't update when nitto did.
  16. Jun 3, 2019 at 7:41 AM
    #36
    Roddy13
    Roddy13 Well-Known Member
    OP keep in mind you really don't want to run those in the winter.
  17. Jun 3, 2019 at 4:08 PM
    #37
    VonStueckle
    Nathan
    Liberty Lake, WA
    I’m in Texas, I’ll be fine
  18. Jun 3, 2019 at 5:41 PM
    #38
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    Why?
  19. Jun 3, 2019 at 11:30 PM
    #39
    VonStueckle
    Nathan
    Liberty Lake, WA
    I want to run them year round as the last time San Antonio got snow of any decent amount was in the 80s....
  20. Jun 3, 2019 at 11:40 PM
    #40
    VonStueckle
    Nathan
    Liberty Lake, WA
    I'm assuming you are talking about not wanting to run them in snow....although not sure why they have an aggressive tread pattern and the angled tread would be decent traction on slippery roads....
