265/70/17 and spidertrax?
Discussion in 'Wheels & Tires' started by gthupman, Apr 9, 2012.
  1. Apr 9, 2012 at 7:57 AM
    gthupman
    gthupman [OP] Well-Known Member
    Greg
    Raleigh, North Carolina
    '17 DCSB Super White Offroad
    i have a 2012 dc sport with stock 17 inch wheels. i want to put 265/70/17 terra grapplers on the truck but would like to to improve the stance without changing wheels. would spidertrax wheel spacers fit along with the increased tire size without any suspension modifications?
    thanks
  2. Apr 9, 2012 at 8:42 AM
    Large
    Large Red
    Yes but you will probably rub..
  3. Apr 9, 2012 at 9:14 AM
    gthupman
    Greg
    how bad do you propose the rub would be ? has anyone tried this particular setup?
  4. Apr 9, 2012 at 9:21 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Minimal rub, I wouldn't go over 1 1/4 spacer
  5. Apr 9, 2012 at 10:30 AM
    gthupman
    Greg
    is the rub constant? require trimming ?
  6. Apr 9, 2012 at 1:16 PM
    Large
    Large Red
    Only when turning.. Maybe 3/4 of the way lock. Not sure
  7. Apr 9, 2012 at 3:20 PM
    JC47
    JC47 Well-Known Member
    British Columbia
    08 TRD Sport DCLB 4X4
    OME 885, 5100's, 1.5 AAL, DC2's, 265/75/16 Duratracs. Leer Cap, Debadged.
    Not sure if this helps any, but I have the same diameter tires with aftermarket wheels that stick out almost 2" from stock, along with a 2.5" lift and the tires did rub the mudflaps and the front part of the inner fender. Minor trimming to fix it though.
  8. Jun 2, 2013 at 8:52 AM
    StreetTaco4Me
    StreetTaco4Me Taco Shot
    Bryan
    Ventura County, So. Cal.
    2001 4runner SR5
    looking to replace shocks and add spacer lift...I do not off road at all just like the height of a lift
    when you say minor trimming what exactly does that mean?
    what do you trim with?
    how much?
    and where?
