265/70/17 packages???
Discussion in 'Wheels & Tires' started by Troyton, May 5, 2013.
  1. May 5, 2013 at 7:34 AM
    Troyton
    Troyton [OP] Well-Known Member
    Troy
    South Florida (Naples)
    06 DoubleCab PreRunner "Wanna be XSP"
    -Trd shocks -Clifford Alarm System -Kenwood Radio -Led bars -Green Fog Lights -2010 Head lights and Tail lights -2010 Tail gate with Back up Camera -White Dash Mod -2011 grill -Led Pods -Kicker Subs -PA System - Underglow
    Ive got an 05 PreRunner V6 TRD package, and I need to know if anyone has information on where to get 265/70/17 tires WITH wheels included? I dont want to have to order a seperate set of wheels and they end up not fitting? Or if I get 265/70/17, what size wheels do I get?
    Thanks
  2. May 5, 2013 at 7:38 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
  3. May 5, 2013 at 10:21 AM
    Troyton
    Troy
    yess i know that but does the width of the wheel matter?
  4. May 5, 2013 at 10:29 AM
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 DuraTrac 16X8.5 Level 8 Trackers HID, LED interior, 3" N-Fab step bars
  5. May 5, 2013 at 10:38 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    Lol sorry i know i wasnt much help. Tire rack says 7-8.5" width for that size tire. Do you have a wheel or wheels in mind that you are looking at?
  6. May 5, 2013 at 3:59 PM
    Troyton
    Troy
    thankyou for the information. but i was looking at the Mickey Thompson SideBiter Truck Wheels. and for 265/70/17, what would be the width of the wheel?
  7. Jul 15, 2013 at 3:32 PM
    slednek
    slednek Member
    S.W. Idaho
    2013 DCSB TRD Sport
    20% Tint - - Smoked Bug Shield - - TRD Grill Badge - 265/70/17 BFG T/A - - 17x8 Rims with 4.5" back spacing - - Black Painted Grill Emblem - - AMP Power Steps - - Under Cover Tri-Fold Tonneau Bed Cover - - 3" RevTek Lift
    According to Mickey Thompson website those only come in 17x9, and a 5in backspace, those will not work well without some mods, such as UCA's, spacers and probably cutting.
    But to answer your question, a 265 should not be mounted on a 9in rim, it's too narrow.
    If you do mount them on there, it is likely that you will rub, and the risk of the tire bead coming off the rim is higher.
    The rubbing is going to depend on your wheel offset, backspacing, ride height of your rig, camber, etc. but bone stock & fresh suspension will likely rub with a 9in rim
    I don't know what kind of driving you do, but if you're off road at all, I wouldn't go any wider than 8in with 265's.
  8. Jul 15, 2013 at 9:39 PM
    Penz83
    Penz83 Well-Known Member
    05 Tacoma pre runner dbcb short bed
    Just an FYI mounting a 265 on a 9" wide wheel is not a bad thing-so long as the tire manufacturer lists that width in there range. For example I have 265/70/17 grabber AT2's on 17x9 wheels. No problems at all. General tire says up to 9.5" on their website for my specific tire. So whatever you plan to go with do your homework and make sure all the parts are compatible.
