265/70/17 PSI HELP !!!!!
Discussion in 'Wheels & Tires' started by dalexander, Jul 8, 2012.
  1. Jul 8, 2012 at 5:10 PM
    dalexander
    dalexander [OP] Member
    alaska
    Since it's way to wet here to do a chalk test, was wondering what pressure to start with on my new 265/70/17 BFG AT's on my stock 08 Sport DC short bed. I have 34psi in front and 32psi in rear, does that sound about right? Thanks for your help.
  2. Jul 8, 2012 at 5:13 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    That's fine
  3. Jul 8, 2012 at 5:22 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    What load range are the tires?
    34 front, 32 rear sounds fine but for a load D or E tire, that might be a little light.
  4. Jul 8, 2012 at 5:33 PM
    dalexander
    alaska
    They are "c" load.
  5. Jul 8, 2012 at 5:35 PM
    OZ-T
    Peter North
    British Columbia
    I ran my E load Hankook MT 265/70/17 at 34 psi no problem
  6. Jul 8, 2012 at 5:35 PM
    enjm10
    enjm10 Well-Known Member
    Eric
    NM
    07 V6 4x4 Silver Streak
    20% tint all around, 5100s all four corners w rear aal, step bars, windshield visors, foglight anytime mod, front black lip, door emblems blacked out, satoshi grill, avid light bar, dash light mod blue, also did my own stereo led mod
    I run around 34-35 on same tire same.size n have had evn wear through the last 15,000 miles with religious rotation
  7. Jul 8, 2012 at 7:44 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    I run 34-35psi all around and I've gotten pretty even wear so far.
  8. Jul 8, 2012 at 7:50 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    2004 SR5 TRD tacoma
    Camburg LT
    That sounds about right. I have 35psi in all four tires.
  9. Jul 8, 2012 at 8:19 PM
    dalexander
    alaska
    Just figuring the weight difference for the 2 extra lbs in front? Lots of rain here now.
  10. Jul 8, 2012 at 10:47 PM
    OZ-T
    Peter North
    British Columbia
    The front of the truck is heavier than the rear
  11. Jul 9, 2012 at 7:01 PM
    dalexander
    alaska
    Yes, that's why I added the extra 2lbs to the fronts. Was just kinda wondering what you guys were doing pressure wise with the same set up.
