265/70-17 Rubbing after Wheel Spacers
Discussion in 'Wheels & Tires' started by whitebread, Jun 5, 2010.
  1. Jun 5, 2010 at 5:10 PM
    whitebread
    whitebread [OP] Well-Known Member
    Raleigh, NC
    2011 4x4 DCSB TRD Off-Road
    Leer 100XL and a bunch of off-roading scars.
    I have an OME lift with stock wheels and Goodyear Wrangler Duratrac 265/70-17 tires. Last week I put on Spirdertrax wheel spacers (1.25") because it seems to make sense to widen the track when you increase the center of mass and roll centers...to hopefully get a more stable ride than without them. I see ToyTec includes papers stating something similar with their lift kits.
    Before the spacers I had no rubbing. Now I get rubbing on the right front tire when backing up and turning, and both front tires when turning and hitting bumps (like pulling into my driveway).
    I went with 265s instead of 285s because research showed I wouldn't have to trim my fender wells.
    Other than trimming the wheel liner or removing the spacers do I have any options? Would Bushwhacker flares take care of this?
  2. Jun 5, 2010 at 5:12 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    did you take your mud flaps off... because you shouldnt be rubbing with 265s
  3. Jun 5, 2010 at 5:18 PM
    whitebread
    Raleigh, NC
    No I didn't take my mudflaps off. I didn't know that was part of the requirements. You are saying it is the mud flap rubbing?
  4. Jun 5, 2010 at 5:18 PM
    misterquad
    misterquad Well-Known Member
    I will upset several people but just take the spacers off.
    I personally don't like the spacers on a vehicle because I worry about safety.
    Let the flaming begin.
  5. Jun 5, 2010 at 5:25 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    its just might be...
    go take a look, when I had my 265s at stock height I rubbed on the mud flaps reversing and thats with new wheels too.
    I've never heard of a case where 265 did not rub on the mud flaps...especially when backing up
  6. Jun 5, 2010 at 5:29 PM
    AZtacoma05
    AZtacoma05 Well-Known Member
    Austin, TX
    17 DCSB TRD Off Road
    ^^^ You are entitled to your opinion but the OP obviously wants to keep em..
    Ya take off your mud flaps.. Its not really the mudflap that rubs but the piece that attaches it to the inside of your wheel well. If you look toward the inside bottom corner of the piece that holds on the flap you'll probably see where its rubbing. I'm running 275/65r17 with no lift and no spacers and had to remove them and I've still rubbed a little bit of my fender off but nothing noticeable from the outside. Also this should also be for the front not the rear... and be aware of your local laws if you do decide to take them off as it may be illegal to drive without them as i believe it is here in AZ.. although you're most likely not going to get pulled over for not having them but if you don't cooperate when you get pulled over they may throw it on the ticket just cause.
  7. Jun 5, 2010 at 5:30 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Mine rub BAD on my wheel well plastic..... 1.5" All-Pro spacers.
    Just take a Dremel to anything that rubs....
  8. Jun 5, 2010 at 5:33 PM
    whitebread
    Raleigh, NC
    Okay, thanks for the input. I will look closer at the flaps...I looked to see if I could see any marks on there, but maybe I didn't look close enough.
    As for safety issues with spacers. My day job deals with designing mechanical components, some of which are mechanically similar to a wheel/axle assmebly. If torqued properly there should be no safety issues with the Spidertrax brand...it appears to be a very well designed product. Thank you for the concern though!
  9. Jun 5, 2010 at 5:56 PM
    misterquad
    Cool - I am glad you understand the concerns - few do. They get themselves into trouble.
  10. Jun 5, 2010 at 6:00 PM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    I rub with the 265/70/17s Duratracs as well. In my case I have a 17x9 with 4.5 backspacing so it pushes the tires out further than stock wheels. I believe that's what's causing the rubbing. I took of the mud flaps and they rub less, but yes, they still do rub. In your case it might be the wheels spacers.
  11. Jun 5, 2010 at 6:48 PM
    Lentsnh
    Anything does what its supposed to if its torqued correctly. Usually failures is due to incorrect installation.
  12. Jun 8, 2010 at 5:27 AM
    misterquad
    I was reading a thread on Expedition Portal last night and a Discount Tire store in Arizona refused service to this guy and refunded his money once they got the truck in the air and found spacers on it.
    Based on my personal experience here in San Antonio, Discount and NTB won't service your truck with spacers on it.
  13. Jun 8, 2010 at 5:29 AM
    tim920
    Tim
    Boston, MA
    ^I've heard (it's funny how we use the word "hear" or "heard" on forums) the same thing on here before.
  14. Jun 8, 2010 at 5:30 AM
    whitebread
    Raleigh, NC
    I did check with my Toyota dealer and they have "no concerns" with spacers. Of course my service adviser is an off road guy.
