265 70 17 Will It Fit On Non Lifted Truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09tacomg, Jun 17, 2009.
  1. Jun 18, 2009 at 11:13 AM
    09tacomg
    09tacomg [OP] Active Member
    USA
    09 DC TRD Sport SW
    Leer 100R
  2. Jun 18, 2009 at 11:19 AM
    SilverStreakUSMC
    SilverStreakUSMC Member
    Charlottesville, VA
  3. Jun 18, 2009 at 4:26 PM
    09 tacoma trd
    09 tacoma trd Well-Known Member
    ontario, canada
    2009 black tacoma dbl cab trd sport
    i am using 265/70/17 dunlop rovers with no rub
  4. Sep 13, 2012 at 10:47 PM
    Jareds Toyota
    Jareds Toyota Well-Known Member
    Jared
    Washington
    2008 AC TRD Sport
    If they rub, just pull off the front mud flaps and your issues will be resolved. I'm running 265/70/17 on procomp 17x8 4.5 bs and have no problems.
  5. Sep 13, 2012 at 10:50 PM
    spares
    spares Canadian Bacon
    New Brunswick, Canada
    06 DCSB TRD Sport
  6. Feb 4, 2016 at 7:08 PM
    TD3106
    TD3106 New Member
    Los Angeles
    08 preRunner
    Hey fellas I'm shopping around also. I have a 08 prerunner. So if I get bf g's 265/70/17 I'll have no rubbing?
  7. Feb 4, 2016 at 8:48 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    What kind rims ? I ran 265/70/17 on 2010 4runner rims and didn't rub. I even lowered with tundra racing kit and had no rubbing issues. Think factory rims shouldn't be a problem.
  8. Feb 4, 2016 at 8:49 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    They'll fit fine on stock wheels
    hemitruk likes this.
  9. Feb 4, 2016 at 9:36 PM
    TD3106
    TD3106 New Member
    Los Angeles
    08 preRunner
    Going with some aftermarket wheels. Fuel vector. So I might have an issue?
  10. Feb 4, 2016 at 9:37 PM
    OZ-T
    Peter North
    British Columbia
    Depends on the backspacing etc
  11. Feb 4, 2016 at 9:45 PM
    TD3106
    TD3106 New Member
    Los Angeles
    08 preRunner
    Oh ok. Have to look into the specs of the wheel. Thanks man.
  12. Feb 5, 2016 at 4:58 PM
    yazmatic
    yazmatic Well-Known Member
    Paul
    2012 DCSB TRD SPORT
    Bilstein 5100's Eibach 620 springs SCS Stealth 6 Matte Bronze BF Goodrich All Terrain TA KO2 265/70/17 SOS Front Bumper Full Hoops Safari AirFlow Snorkel
    Hey guys.....sorry to hijack this thread but I'm in the same boat. Currently running an all stock 2012 double cab TRD sport short bed.
    Tires/wheel: 265/60/18.
    I'll be getting bilsteins all around in a week or two and looking to change my wheel set up. If I get this wheel and tire combination, will there be any rubbing? Will the wheel fit the tire?
    Thanks all.
    http://www.4wheelparts.com/Tires/LT...tl00_ContentPlaceHolder1_pDetail_productSpecs
    http://www.ebay.com/itm/like/361090...7290-0%26rvr_id%3D977793289018&chn=ps&lpid=82
  13. Feb 5, 2016 at 5:53 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Have 265 70 R17's BFG ALL TERRAIN on my 08, no lift, never have had a problem.
    Even have the spare tucked up under, same brand tire, same size and even with the same style rim, no problems with that either.
  14. Feb 5, 2016 at 7:17 PM
    Dropitmore
    Dropitmore Panda Man
    Andy
    Downey, CA
    2013 TRD McDouble Cab
    Mall Crawler Edition
  15. Feb 5, 2016 at 7:21 PM
    #35
    Dropitmore
    Andy
    Downey, CA
    Do it, it makes the world of difference. Helped me get by before finally figuring out what lift I wanted.
    canopycarl[QUOTED] likes this.
  16. Feb 5, 2016 at 7:49 PM
    #36
    yazmatic
    Paul
    2012 DCSB TRD SPORT
    about to do the same thing. 265/70/17 BFG ALL TERRAIN KO2 and procomp 7105 17X8 (for now). youll probaby get it done before me. let me know how it goes
  17. Oct 24, 2018 at 3:59 PM
    #37
    mattcoco35
    mattcoco35 New Member
    A Work In progres 2015 Taco
    Getting started....
    I'm getting the BFG All-Terrains 265/70 R17 this weekend on my stock 17" wheels - my Tacoma is 2015 - I'll come back with some pics next week - fingers crossed.
    I moved ahead on the sizing after reading this article: https://parts.olathetoyota.com/blog/4536/toyota-tacoma-tire-sizes
    Is states:
    Over-Sized 2005+ Tacoma Tires
    Note: These recommendations are based on the factory wheels. Using an upgraded rim with different backspacing will allow you to increase to a wider tire. Also, if you go really wide (more than 285), you will want to consider fender flares.
    No Lift Kit
    Max tire sizes are:
    15″ rims: 265/75 R15 – A 265/80 R15 tire would fit just fine, but no one makes one to our knowledge. 265/75 R15 is the largest available size.
    16″ rims: 265/75 R16 – one inch taller but same width as factory
    17″ rims: 265/70 R17 – one inch taller but same width as factory
