265/70/17's rubbing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by andersonphoto, Jul 1, 2016.
  1. Jul 2, 2016 at 5:55 AM
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    did you run these wheels before your lift w/o rubbing issues?
  2. Jul 2, 2016 at 6:45 AM
    SoCalRandy
    SoCalRandy Well-Known Member
    San Diego
    2016 Tacoma TRD Sport Long Bed Double Cab 2WD
    Yes, I had the same wheel and tire combo prior to putting the coilovers on.
  3. Jul 2, 2016 at 2:06 PM
    andersonphoto
    andersonphoto [OP] Well-Known Member
    Jared
    2016 DC TRD Sport
    they are 8.5 wide
  4. Jul 3, 2016 at 6:52 AM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    where was the rubbing?
  5. Jul 3, 2016 at 6:53 AM
    90yota
    88 T4R / 15 F350
    Stock....ish
    thinking about running the same tire but my wheels are -10 offset
  6. Jul 3, 2016 at 11:41 AM
    andersonphoto
    Jared
    2016 DC TRD Sport
    I think in the back of the fender liner. I really haven't checked for sure yet.
  7. Jul 4, 2016 at 11:09 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    ^^^ That = not enough negative offset - I have the same size tires with -6 offset and no rub..
  8. Jul 4, 2016 at 10:52 PM
    CaptainSkipper
    CaptainSkipper Active Member
    2016 QS TRD Sport DCSB M/T
    I'm so glad you made this post, I just ordered some Method Roost wheels and was planning on going with the same size tire. Now I haven't decided whether or not to lift or go with a smaller tire.
  9. Jul 5, 2016 at 6:44 AM
    andersonphoto
    Jared
    2016 DC TRD Sport
    No problem. Thats exactly why I posted it, just in case someone else was looking at the "same" setup and what to expect.
    danielgonzzz likes this.
  10. Jul 5, 2016 at 7:19 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Someone help me out here?
    Are we talking rim width or wheel width here?
    Stock is 7.5" wide, +30mm offset=4.75" backspacing.
    His are 8.5" wide, 0 offset=4.25" backspacing.
    Yours are 8.5" wide, -6mm offset=4" backspace.
    Had I used rim width, backspacing would be increased 1/4"; assuming wheel width is typically, rim width + 1/2"?
    Basically, does OP's wheels have 4.25" or 4.5" backspacing?
  11. Jul 5, 2016 at 7:22 AM
    b5gt28
    b5gt28 Active Member
    Western NY
    '11 DCSB Off Road
    I'm running 265/70/17 Mamba M14 17x9 -12 Et and they rubbed like crazy at stock height. It's the offset of the rim that causes mine to rub on the inner fenders front and rear, I cut most of it out and modified my front mudflaps and it got rid of 95% of the rubbing. Now it's only rubbing at full lock with additional weight (passengers) or if I'm cranked and I hit a bump like pulling in my driveway.
    I've been waiting for almost 3 months for my 3" lift to arrive which will hopefully get rid of all of the rubbing. If not, it was a risk I was willing to take when I decided to go with 9" rims and the -12 offset to get 265's to stick out a little.
    I will suggest switching to the Husky front flaps, their design is slightly better than the factory flaps and doesn't rub as bad. I still had to trim mine further, but it was a def improvement over stock. They're also shorter so you don't bash them every time you pull into a driveway.
  12. Sep 5, 2017 at 2:28 PM
    gpuccion
    gpuccion Well-Known Member
    2017 Inferno Tacoma TRD Sport DC LB
    Split- chatting with you on another similar thread... I've got my wheels/ tires narrowed down and am interested in finding out if I'll have rub issues, and what offset to get to minimize that chance. You linked a rim and tire size calculator that seemed to help. Looking at the Ultra Mongoose 178 17x9. Looking to match with Falken Wildpeak's 265/70R17. I have stock '17 TRD Sport w/ 265/65R17's (7.5" rim, 30 offset). My question becomes this... looking under my front end, there doesn't seem to be a whole lot of room between the tire and suspension parts (visually less than the UCA). The offsets offered in that rim are 1, 12 and 25, so basically 1 would be out b/c it would push em too far out and there'd definitely be fender issues. What's the best option between the 12 and 25's? My understanding is that the 12's will have a 1/2" more of BS than stock, and the 25's will have 3/4" more of BS. 12's will stick out 3/4" further than stock, and 25's will stick out 1/4" more than stock. What I don't know besides how it will look in terms of sticking out from stock, is what will have less clearance issues on fender/ UCA/ suspension parts? I'd like to NOT go way wider than stock, as I'd be worried about mud and rocks getting thrown up against the side of my truck like my old nissan did with a much wider stance... is 3/4 a lot in the real world? Seems negligible with a ruler in front of my face... Thoughts??
  13. Sep 5, 2017 at 3:17 PM
    Silvertaco44
    Silvertaco44 Member
    New Mexico
    2016 Tacoma trd offroad
    I have 265 70 17 Toyo open country ATs on Method standards. No rub and I wheel the heck out of it no rub whatso ever.
  14. Sep 5, 2017 at 5:43 PM
    splitbolt
    NW Arkansas
    Stock rim has 5.5" backspace.
    17x9 et+1mm has 5" bs, tire will poke 29mm, wheel will poke 48mm
    17x9 et +12mm has 5.5" bs, tire will poke 18mm, wheel will poke 37mm
    17x9 et +25mm has 6"bs, tire will poke 5mm, wheel will poke 24mm
    ET +25mm is out; too much backspace.
    ET +12mm is your best bet; same backspace as stock and minimal poke.
  15. Sep 5, 2017 at 8:44 PM
    #35
    gpuccion
    Just talked with a local shop and he thinks going with a larger tire (265/70r17) and a 17x9 wheel, he doesn't think ANY combination of backspacing will "safely" work. Wasn't as concerned about the backspacing causing rubbing on UCA's or suspension parts in the back, but mainly fender rubbing issues. Kinda killed my mod mojo! Does he have a point to some degree? I'd hate to spend all the money on new tires and rims and have rubbing that can't be fixed besides a lift (although that, in an ideal world, would also be in the future - 2" or less, as well). Now if it's just rubbing from some serious offroading loading under full travel, I'm not to worried, but I don't want rubbing from cornering hard on the freeway offramp! What to do....
  16. Sep 5, 2017 at 10:23 PM
    #36
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Did you look where you're rubbing?
    I have duratrac in same size on a 0 offset wheel and I was rubbing on the front mud flap that's all. Remove them and you're fine. Or remove them and still do lift cause you're clearly just trying to justify a lift lol
  17. Sep 6, 2017 at 12:29 AM
    #37
    gpuccion
    You have 265/70r17 on a 17x9 wheel with stock suspension? If so, that's encouraging to hear... You're probably ultimately right about the lift, but I don't really want to!:)
    BTW - I found a member on here that has those rims at least... Again being new, I'm not aware of any direct messaging to try and contact him for info. WE have an inbox, but how do I send him a message?
  18. Sep 6, 2017 at 12:57 AM
    #38
    bear_okababa
    bear_okababa Well-Known Member
    Honolulu, HI
    2017 Tacoma TRD OR DCSB MT
    What is the width of your method wheels? The TRD Pro wheel is +4mm and the methods are 0mm. TRD Pro wheel is 17x7. I don't think the 4mm difference is the cause. Most likely it is the width of the merhod rim. Anyone else agree?
  19. Sep 6, 2017 at 1:02 AM
    #39
    Toyo_newb
    Toyo_newb Well-Known Member
    Matthew
    2017 DCLB TRD OR 4x4 QUICKSAND
    I've only rubbed a few time while wheeling the truck fairly hard on trails. Didn't sound too bad, and I'm pretty sure it was the cab mount. No big chunks missing from the tires, but a CMC is my next mod. I'm on 17x8.5, 0 offset with the 265/70r17 KO2's.
  20. Sep 6, 2017 at 3:16 AM
    #40
    splitbolt
    NW Arkansas
    Click on their username and "start a conversation".
