265/70r17 BFG KO2 MPG Impact?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jjbell83, Nov 29, 2015.
  1. Oct 20, 2016 at 10:59 AM
    17Taco
    17Taco Well-Known Member
    Brad
    2017 Inferno Tacoma TRD off road
    Also, pictures don't do them justice. I would definitely recommend them.
  2. Oct 20, 2016 at 10:59 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    a 285 70 17 E rated is only 9lbs more...
  3. Oct 20, 2016 at 11:14 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    I never had the stock stuff on long enough to be able to comment on the shifting. I love mine.
    G.
  4. Oct 20, 2016 at 11:59 AM
    BarberRider
    BarberRider Merit Badges: Scuba Cliff diving Mirror Awareness
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    It's got a cop motor, a 440-cubic-inch plant. It's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
    265/75/16 E
    lost 2-3mpg and noticable power loss
  5. Oct 20, 2016 at 12:00 PM
    TRDPro4x4
    TRDPro4x4 Well-Known Member
    The OP asked about 265/70/17's which the BF KO2's weight 46lbs each in load range C. 9lbs more than the stock Goodyear Adv w.kevlar load range T.
    The 285 70 17 E BF KO2 is 58lbs.. 21lbs over stock.
    T4RFTMFW likes this.
  6. Oct 20, 2016 at 12:05 PM
    TRDPro4x4
    It's not really apples to apples because he has the option to get load range C instead of E. That's 7lbs per tire saved.
  7. Oct 20, 2016 at 12:06 PM
    Joe23
    I was thinking Cooper St Maxx, 55lbs E rated.
    But if thats the case does fuel loss go linear? if you lose 1mpg per 9lbs?
  8. Oct 20, 2016 at 12:20 PM
    TRDPro4x4
    No I don't think there is a direct correlation there. Tread patterns between all-season, A/T and M/T will play a role in rolling resistance. Added tire and wheel weight are obviously the worse thing you can do if you care about mpgs though. 1lb of unsprung weight = 10lbs of sprung weight so adding 21lbs more per tire over stock= 21x4=84 x10=840lbs in the bed of the truck..
    Joe23[QUOTED] likes this.
  9. Oct 20, 2016 at 1:50 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Im 19-22 mpg, 87 octane, with C rated version on pro wheels. DCLB 4WD auto.
    Joe23 likes this.
  10. Oct 20, 2016 at 2:13 PM
    2016MGMTACO
    2016MGMTACO Well-Known Member
    I'm getting 19-20 mpg with C rated version on pro wheels, this is on an access cab with a Flippac.
  11. Oct 20, 2016 at 2:42 PM
    Joe23
    I wonder what the fuel loss would be with the e rated.
    I'd rather not have e rated but once you get into a 32 or larger they all seem to be e rated.
  12. Oct 20, 2016 at 2:45 PM
    ZachMX
    When I had my lifted trucks, E rated toyo open country's which were the lightest 285s AT at the time (41 lbs), I had a good 2-3 mpg loss, never got better than 17 mpg usually.
    Though I know a lot of full size trucks get 21 mpg consistenly I am very happy with my turd gen's mpg especially with the BFG KO2s.
  13. Oct 20, 2016 at 2:48 PM
    Joe23
    That was on a second gen though so I think 3rd gen would do better since from factory it is supposed to have better mpg.
    I wonder if you could get 18-19.
  14. Oct 20, 2016 at 2:49 PM
    ZachMX
    But you can bet on the same mpg loss, so 16-20 mpg, dosent matter its a different truck, its still a heavier tire and will decrease your mpg accordingly, not to mention the gearing is different too, so may feel more sluggish than a 2nd gen. Best to ask around in the lifted thread, a lot of those guys are running 32+
  15. Oct 20, 2016 at 2:58 PM
    #35
    Joe23
    I can't decide what to go with. I mean regardless I'm looking into the Cooper st maxx but they're all e rated.
    I daily drive so need to keep mpg
    But need something that will be good for the trails so 33 would be best. But a 285 will kill mpg and will need cmc which I'm not overly fond with doing.
    265 will only get me 31.8 inch. 275 would only get 32.2. I could deal with the 275 but again needs cmc under flex
  16. Oct 20, 2016 at 3:00 PM
    #36
    ZachMX
    I love my 265s, everyone asks if my truck is lifted or leveled, nope, all stock, no more lift nuances for this guy. The 265's should be fine for the trail, if anything your articulation and suspenders will be what matters, that and a rear locker.
  17. Oct 20, 2016 at 3:06 PM
    #37
    Joe23
    I'll be doing full fox extended travel lift to get more flex etc.
    When I had my jeep it was with 33s. Most the trails I go to are rated for 33. You can do them with 32 if you know what you're doing.
    I'm going to be doing a lot of overlanding so not sure which to go with
  18. Oct 20, 2016 at 3:07 PM
    #38
    Threerun
    Threerun Well-Known Member
    Lost in Montana *recalculating*
    2016 Silverado LTZ
    6.2L 8spd stock
    I'm running 265 Cooper ST/Maxx with a modest suspension upgrade and I've been on a lot of forest roads/offroad. Honestly I can't think of any place I would go that would require a 285 over a 265.
    Also the traction on the ST/Maxx's are great. I spent a week up in NE Montana hunting- hardly any pavement all week, wet muddy, rutted roads, wet, soft prairie grass 'muck' and they are spectacular. Only needed 4wd once the entire trip.
  19. Oct 20, 2016 at 3:12 PM
    #39
    kevinlambchops
    kevinlambchops Well-Known Member
    do you have any pictures? I have a '16 DCLB, debating whether or not I want to lift the truck or just put some meaty tires on it and enjoy it as it is.
  20. Oct 20, 2016 at 3:13 PM
    #40
    ZachMX
    My sig.
