265/75/16 BFG A/T KO rubbing on stock 2004 dbl cab
Discussion in '1st Gen. Tacomas (1995-2004)' started by cjbrown, Oct 10, 2013.
  1. Oct 17, 2013 at 5:55 AM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I have the understanding that those are designed to provide 3" of lift. I'm not trying to lift my truck
  2. Oct 17, 2013 at 10:32 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    OME 880's are probably what you want. Should be about 1" of lift unloaded, then add your bumper and winch. Otherwise I'm not sure of any other coils designed to handle the additional weight without lifting. I'm sure they're out there though. You could also call up Toytec and tell them what you want, they should be able to find something for you.
  3. Oct 17, 2013 at 3:49 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Okay thanks. If my garage is slightly level (which it probably isn't), the bumper and winch seemed to pull down the front about an inch. I'm for sure on getting 5100s, just thought i should replace the coils as well to kinda help support the weight. Unless, if that is completely unnecessary, I won't do it. I am just unsure...
