265/75/16 drifting issue?
Discussion in 'Wheels & Tires' started by matth, Jun 4, 2010.
  1. Jun 4, 2010 at 1:33 AM
    matth
    matth [OP] New Member
    Bella Vista, AR
    07 PreRunner SR5 Reg Cab
    About a month ago i upgreded from the stock 245/75/16 to 265/75/16 BFG AT's on the stock wheels.
    The problem is now the truck seems to want to drift from side to side at high speeds. Also when going over bumps on the interstate the steering wheel shakes and it feels like the tire is coming off the ground.
    2 questions:
    What is the stock 16in wheel's width?
    Do you think going to a wider wheel would help?
  2. Jun 4, 2010 at 1:55 AM
    matth
    Bella Vista, AR
    No bumps or potholes -
    It's been doing it from day one. I even took it back to the tire place and they rebalanced and said there was nothing wrong with the tires.
  3. Jun 4, 2010 at 2:08 AM
    matth
    Bella Vista, AR
    I'm talking 75 on the interstate. What i can't figure is that with the stock tires i could set the cruise at 75 and not touch the wheel and it would drive perfectly straight.
    Thanks for the advice :)
  4. Jun 4, 2010 at 4:14 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    What's your tire pressure at? I set mine at 32 front and 29 rear. I know it sounds low but that's what Toyota recomends. That should soften up your ride and help it drive straight. These trucks do tend to wander a little bit. There is a bulletin out on this issue. Try the air pressure drop first and see if that helps.
  5. Jun 4, 2010 at 5:51 AM
    Brunes
    Brunes abides.
    Rotorhead
    The pressure that Toyota "recommends" only applies to the stock brand/style of tire in the stock size.
    Use the chalk line test to determine best pressure for tires all the time- Gives you the best baseline for your vehical...with your gear and weight and everything.
  6. Jun 4, 2010 at 6:59 AM
    TacoSupreem
    Hayden
    Kentucky
    The vehicles weight has alot to do with the recommended tire pressure. The bfg at's have a high max air pressure but you don't need to run that much pressure. The 32 front 29 rear is a good baseline and you can tweek it from there. If your pulling a trailer or hauling something heavy then you'll need to increase you air pressure.
  7. Jun 7, 2010 at 7:45 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    I might be off here... but you said rebalance... what about getting a realignment?
