265/75/16 mounted on 16x10 wheels
Discussion in 'Wheels & Tires' started by jrider636, Jun 24, 2010.
  1. Jun 24, 2010 at 10:27 AM
    jrider636
    jrider636 [OP] Well-Known Member
    justin
    tally,fl
    08 tacoma prerunner
    looked under previous threads for this but does anyone have this setup on their truck? about to order em and wanted to see how they look first or if theyd even look right
    thanks
  2. Jun 24, 2010 at 10:34 AM
    HOSS454
    HOSS454 Well-Known Member
    Pukalani
    08 Sport
    Bolt ons here and there
    i got goodyear duratracs in 265/70 17s on 17x10s. it is kinda stretched out but if that is the look you are going for, then that is up to you. donʻt have any pics but the center section is about 12.5 inches on the 10" rims. hope this helps. and what kind of tires you looking to get?
  3. Jun 24, 2010 at 10:41 AM
    jrider636
    justin
    tally,fl
    08 tacoma prerunner
    it does help and thanks. i was lookn at the duratracs or hankook something. cant decide
  4. Jun 24, 2010 at 10:46 AM
    HOSS454
    Pukalani
    08 Sport
    i also got some 16x10s and was looking at the 285/70 16 nitto trail grapplers. same height as the 265/75 16s but just a tad wider.
  5. Jun 24, 2010 at 10:47 AM
    whitetaco02
    whitetaco02 Well-Known Member
    Frank
    GA
    09 Tacoma 4x4
    Tinted windows, stainless steel drop hitch, rear TSB, Marathon seat covers in Realtree AP camo, low profile chrome toolbox, husky liners front and back, debadged
    Do you have a lift? If not you are going to look like a skateboard in my opinion. But, if that is the look you are going for then get it!
  6. Jun 24, 2010 at 10:54 AM
    jrider636
    justin
    tally,fl
    08 tacoma prerunner
    no lift. just like the wide stance with the biggest tire that will fit. also dont want it to look all crazy, like a skateboard. guess i could look harder for pics
  7. Jun 24, 2010 at 12:48 PM
    whitetaco02
    Frank
    GA
    09 Tacoma 4x4
    It would look pretty bad in my opinion. Got with a 16x8 and you should be good to go. Not to mention if you go with a 16x10 you will more than likely rub at full turn.
  8. Jun 24, 2010 at 12:50 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    I think if the tire is being "stretched" out to fit onto the wheel then the tread may wear unevenly, yes or no??
  9. Jun 24, 2010 at 2:15 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    The stretching of the sidewall doesn't effect the tread its self. Sports cars run stretched tires all day long.
  10. Jun 24, 2010 at 3:41 PM
    HOSS454
    Pukalani
    08 Sport
    x2... you are right, you will rub. i rub mine and i have the bilsteins set at 2.5 in the front..
  11. Jun 24, 2010 at 3:51 PM
    shocker01
    shocker01 Well-Known Member
    Gordon
    Ky
    01 Tacoma 4x4 TRD
    5100 Billies, drop-in k&n, deck plate, gray wire, Dynomax exhaust.
    Go for it dude.
  12. Jun 24, 2010 at 4:54 PM
    HOSS454
    Pukalani
    08 Sport
    those swampers are actually smaller in diameter than the 265 duratracs... i have both...
  13. Feb 22, 2014 at 7:47 PM
    02coma
    02coma Well-Known Member
    la puente
    02 dc
    Any pic 265 75 16 on 16x10 pls
  14. Feb 8, 2016 at 5:37 PM
    runninvakennels
    runninvakennels Member
    Ben
    2012 Tacoma TRD
    Just ordered 3 inch lift and 16x10 pro comp wheels pics to come soon
    Bump I'd like to see some pics
  15. Apr 11, 2016 at 3:42 PM
    fabcoma
    fabcoma Member
    2013 tacoma abcess cap, 4x4 long bed
    stock for now
    And...... the thread dies here...:mad:
