265/75/16 MT's or 285/70/16 AT's?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1tacoplease, Mar 26, 2014.
  1. Apr 8, 2014 at 10:32 AM
    #41
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Wow. You have changed your mind about 3 times.
    I have 285/75/16 AT with 3 in. lift and I had to cut the cab mount, trim plastic fender and lower my bump stop to prevent any rubbing when my suspension is fully compressed and wheels turned to full lock.
  2. Apr 8, 2014 at 10:44 AM
    #42
    1tacoplease
    1tacoplease [OP] I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    I have changed my mind several times and it's because of all your, much appreciated, opinions. This was just for looks but then I took other variables into consideration and decided that I like both exactly the same. So, I go the easier route, and stick with the 265 with no removing or cutting. If I liked the 285's just a tad better, then I would go through the work, but it's equal. So, thank you everyone. Now show me some aggressive tires.
  3. Apr 8, 2014 at 1:10 PM
    #43
    RightCoast
    RightCoast Well-Known Member
    Brian
    LBI, Nj
    need's more lift
    Toytec adjustable coilovers, camburg UCA, 5100's in the rear, AAL, 285/75-16 Wardens, Level 8 Mk6 wheels,satoshi grill and BHLM.
    Trail grapplers look pretty aggressive
  4. Apr 9, 2014 at 5:50 AM
    #44
    MPLS TACO
    MPLS TACO Well-Known Member
    CHad
    MN
    TRD Sport
    3" Lift with UCA, Grillecraft grille, XD rims w/ 285/70r17 duratracs, leer xq cap,
    Heres the deal if you offroad 285's will need some modifications to not rub while doing so, however with a 3" lift 285's on the road and mudding will not be a crazy issue minor rubbing in reverse full lock and possibly full lock mudding forward. On the road you should have very minor issues if any with running 285's
  5. Apr 9, 2014 at 9:26 AM
    #45
    1tacoplease
    Temecula
    But I have a 2.5" inch lift with stock UCA'S and Spidertraxx 1.25" spacers and I rubbed a little on driver side (w/ my 265/75/16's) but trimmed right under driverside fog light housing to get rid of it.I like the look of 285's, but I don't want to trim anymore.
  6. Apr 9, 2014 at 10:09 AM
    #46
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    if you want inexpensive but aggressive tires the best way to go is treadwright.com
  7. Apr 11, 2014 at 5:32 AM
    #47
    MPLS TACO
    CHad
    MN
    TRD Sport
    I think you just answered your question :cheers:
  8. Apr 11, 2014 at 5:50 AM
    #48
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    I just bought the hankook dynopro's atms in 275/70/17 and they are doing great and look great.
  9. Apr 11, 2014 at 6:07 AM
    #49
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    You honestly don't need the spacers with that tire but I'm guessing this is all for the "wide" look. wide = rubbing so you'll have to trim more for each increase (wider or taller)
  10. Apr 11, 2014 at 7:58 AM
    #50
    1tacoplease
    Temecula
    You got pics?
  11. Apr 11, 2014 at 8:20 AM
    #51
    madmex
    madmex Well-Known Member
    Frank
    TX
    '14 TRD Sport 4x4 DCLB
  12. Apr 11, 2014 at 11:48 AM
    #52
    1tacoplease
    Temecula
    Just checked out your pics. Looks good on your truck. Do you have a 2.5" lift? When I used the tire size tool, it's slightly shorter than 265/75 but slightly wider. I'm already running Spidertraxx wheel spacers so I got the wide look. I think the 265's are better for me. Thanks though. I'm leaning towards a MT, just for looks, price, and wieght.
  13. Apr 11, 2014 at 5:00 PM
    #53
    1TUFFTRD
    1TUFFTRD WTF
    06 AC with a skewp
    06 With a Skewp.
    1.5 in the rear.
  14. Apr 11, 2014 at 5:29 PM
    #54
    mkrespke
    mkrespke Well-Known Member
    Phoenix, AZ
    07 4x4
    What wheels are these?
    Btw - I stuck with 265/75/16 with a 3" lift, stock UCA so I wouldn't have to trim anything or worry about rubbing
  15. Apr 11, 2014 at 5:38 PM
    #55
    1TUFFTRD
    1TUFFTRD WTF
    06 AC with a skewp
    06 With a Skewp.
    275 with all pro leaf pack
