265-75-16 Rubbing issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Black Sheep, Jan 29, 2011.
  1. Jan 29, 2011 at 4:36 AM
    Black Sheep
    Black Sheep [OP] Well-Known Member
    Jeff
    Pittsburgh, PA
    2011 Black Dbl Cab TRD T/X Pro
    6" Pro Comp Suspension lift with Pro Comp leveling kit, Bilstein 5100's, Full leather interior with seat heaters, Go Rhino step bars, Sony XNV-770BT Head Unit with NAV, DVD, XM and Blutooth, Tonopro toneau cover, Tinted windows, Black mesh grille, Projector headlights with HID lows, HID fogs, Crystal Eyes rear LED taillights, Weathertech mats front and rear
    Will the 265-75-16's rub with bilsteins set at 1.75 up front? I want to get the Nitto Terra Grapplers LT265-75-16.
  2. Jan 29, 2011 at 4:42 AM
    sneurath
    sneurath Well-Known Member
    shawn
    Hernando
    05 PreRunner SR5
    I had the 265's with no lift and had no rubbing at all.You will be fine.I just put 285/75/16 graplers on the other day i love them.
  3. Jan 29, 2011 at 4:43 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    You'll be A-ok.
  4. Jan 29, 2011 at 5:02 PM
    garagefujimoto
    garagefujimoto Member
    05 TRD
    put on 265/75/16 snow tires on TRD yesterday. no lift. no rub
  5. Jan 29, 2011 at 5:15 PM
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    Lady's Island, SC
    Sand and dog hair
    i'm running 265-75-16 Bridgestone Duelers AT's on all stock suspension - no rub
  6. Jan 29, 2011 at 5:16 PM
    primer
    primer Well-Known Member
    T
    OK
    06 SS Mica AC 4x4 TRD Off-Road
    (Mostly) debadged, Homelink mirror, Elevated rear diff breather, LED illuminated 4x4 switch, Color matched grill surround, Bed cover, Ivan Stewart wheels, Bridgestone 265/75 Dueler AT Revo 2 tires
    I have Revo 2s that size. All stock suspension. I rub a little. My tires are e-rated (10 ply, light truck tires) though. Most people with p rated that size tires don't rub. The stats on the tires list the exact same diameter for p-rated and e-rated, but I'm convinced the e-rated are a little bigger. The tread definitely looks deeper/more aggressive. I'm hoping with Bilstein 5100s at .85 or 1.75 even I wouldn't rub, cause that's how I hope to fix it.
    http://www.toyotanation.com/forum/showthread.php?t=355791&highlight=tsl90
