265/75 16 very close to spindle.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ehawkins2002, Jul 9, 2010.
  1. Jul 9, 2010 at 12:49 PM
    ehawkins2002
    ehawkins2002 [OP] Member
    Pearl, Mississippi
    2010 PreRunner SR5
    Black Grillcraft grill, EGR vent visors, Husky liners
    I have about 1/4 inch gap between my tire and my spindle. Is this normal? I haven't noticed any rubbing as of yet, but have not had these tires long either.
    I am on stock 16 inch gulf states wheels running 265/75 16 tires.
    Should I order spacers or is that enough of a gap?
  2. Jul 9, 2010 at 12:51 PM
    Maintenance Man
    Maintenance Man Well-Known Member
    Justin
    Atlanta, Ga
    05 Tacoma Pre-runner SR5 2.7L
    Leer camper shell; afe stage ll intake; 265's bridgestone dueler tires; rockford's power series 6.5's; tint on all windows; semi de-badged; weathertech digitial mats; grillcraft grill; blacked out headlights with eyelids; blacked out badges; and more to come.
    I'm running same size and rim with no spacer. Never rubbed either
  3. Jul 9, 2010 at 12:56 PM
    revhappyleon
    revhappyleon Well-Known Member
    Manny
    Tampa near macdill
    07 Prerunner V6 6-speed(custom dual exhaust)
    dual exhaust, foglight anytime, satoshi, chlm, aux backup lights and electric fan conversion
    you've got nothing to worry about, the spindle and tire move in unison so if you ever experience rubbing it indicates the hub bearing is worn out.( thats with same size tires of course)
  4. Jul 9, 2010 at 1:01 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    What he said^^ When you hit a bump your wheel/tire go straight up and your LCA, Spindle, UCA and shock/coil move straight up. So nothing gets touched.
    A bad Camber alignment or busted hub is the only way for you to have rubbing against your spindle.
    I had 285 tires on my truck before the wheel spacers and the gap was so small between the "peak" on the side of the spindle and the inside sidewall of the tire, I couldn't put my small finger in between it.
  5. Jul 9, 2010 at 1:36 PM
    ehawkins2002
    Pearl, Mississippi
    2010 PreRunner SR5
    Thanks for all your help. I saw it and got a little freaked out. Still got waayyyy to many payments on it. :)
  6. Jul 9, 2010 at 2:05 PM
    whitetaco02
    whitetaco02 Well-Known Member
    Frank
    GA
    09 Tacoma 4x4
    Tinted windows, stainless steel drop hitch, rear TSB, Marathon seat covers in Realtree AP camo, low profile chrome toolbox, husky liners front and back, debadged
    What is your setup? Specs?
  7. Jul 9, 2010 at 2:35 PM
    ehawkins2002
    Pearl, Mississippi
    2010 PreRunner SR5
    2010 Dbl Cab Prerunner SR5
    Just put some cooper discovery stt's on yesterday. I want to keep the factory wheels mainly because I don't want to deal with balance issues like I have had to do in the past on other vehicles.
    Planning on doing a lift soon, but wouldn't that push the spindle out even closer to the tire, or am I off on that.
  8. Jul 9, 2010 at 5:05 PM
    28ØØ3
    28ØØ3 Well-Known Member
    boss
    somewhere endlessly searching for ways to offend B
    08 DCLB SR5 4WD
    VatoZone Especial
