265 75 17 on 17x9 wheels, how far off will my speedo be?
Discussion in 'Wheels & Tires' started by notslow, Nov 27, 2008.
  1. Nov 27, 2008 at 3:41 AM
    notslow
    notslow [OP] Well-Known Member
    Palm Springs, Ca.
    02 TRD black
    Hi Guys,
    Just got my 2002 TRD it has the stock 16 7.5 wheels with 265 70 16. I am looking to get some new wheels and most of the 17s are 9 inch wide. I did a bunch a reading on here and it looks like 265 75 17 will fit the 17 9 wheel and look right, but is it going to be much taller. The tire calculator doesn't account for wheel width so that doesn't really help me. Anybody running this size have advise?
    Thanks, Will
  2. Nov 27, 2008 at 5:52 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
  3. Nov 27, 2008 at 5:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to Tacoma World!! :)
  4. Nov 27, 2008 at 5:55 AM
    Red Razor
    Red Razor Well-Known Member
    Greensburg PA
    06 TRD Sport 4X4
    265/70-16 is 30.6" tall. The 265/75-17 is 32.7" tall. It is going to look much taller. Are you planning to install a lift? That diameter tire is common for a 3" lift.
    As far as a 265 wide tire on a 9" wide rim, you better check the tire manufacturers specs for acceptable rim width. The max rim width of my 275/70-17's was 8.5".
  5. Nov 27, 2008 at 12:58 PM
    notslow
    Palm Springs, Ca.
    02 TRD black
    Thanks for all the replies. I don't want to do any lift or gear changes. Maybe I am going to have to stick with a 16-8. Red Razor, what width 17s are on your truck? They look like 18s in the picture.
  6. Nov 28, 2008 at 4:56 AM
    Red Razor
    Greensburg PA
    06 TRD Sport 4X4
    In my sig, they are 20X9. I run those with 275/55-20 tires in the summer. In the winter, I run 17X8.5 wheels with 275/70-17 tires.
  7. Nov 28, 2008 at 5:15 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    I'm running 265/70/17 Nitto TG's on 17x9 rims with stock suspension. The Nittos are 31.57" and fit a 9" rim per the manufacturer specs. There is another thread around here that determined a 31-32" tire corrects the speedo error. edit..found it
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/19537-acceptable-speedometer-error.html
  8. Nov 28, 2008 at 5:23 AM
    Ridingontrd
    Richard
    Laughlin,N.V
  9. Nov 28, 2008 at 9:35 AM
    notslow
    Palm Springs, Ca.
    02 TRD black
    Good to know I can go bigger without messing up the speedo. I know the 265/76 17 is at the limit on a 17 9 wheels. Is there a better size tire for the 17 9 on a 1st gen TRD with no lift? Thanks everyone for the good advice.
