265 75/R16 tires require lift???
Discussion in 'Wheels & Tires' started by mccawi02, Jul 20, 2010.
  1. Jul 20, 2010 at 5:56 AM
    mccawi02
    mccawi02 [OP] Active Member
    Bill
    Delmar, NY
    09 DC 4X4 TRD OFFRD
    I know there's a bunch of info out there on tires and max stock size limitations, but on TW I read that someone had to cut off a bit of the inner black plastic of the wheel and tire fender to prevent rubbing with 265 75/R16 tires with a stock suspension....any ideas/experiences with this?
    I'm looking to but Firestone Dest A/T tires at 265 75/R16 and want to keep everything else as is.
    Thanks!
    -Bill
  2. Jul 20, 2010 at 6:30 AM
    kramer2k
    kramer2k Well-Known Member
    Jacksonville, FL
    08 DC PreRunner TRD OR
    I just got Nitto Terra Grapplers in 265/75/16 put on my stock TRD suspension. Everything is fine on mine.
  3. Jul 20, 2010 at 6:43 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I have 265/75/16 duratracs with stock suspension. I didn't have to do any trimming. I still have my mudflaps on.
  4. Jul 20, 2010 at 6:50 AM
    Seener84
    Seener84 Well-Known Member
    Sean
    Denver, CO
    10 DCLB SR5 4x4
    Leer 100R
    My 265 75 16 Hankook ATm's rub when turning hard over bumps. This is with a set of aftermarket wheels with some backspacing. Thinking about going down to 265 70 16 because it annoys me even though it isnt rubbing bad at all.
  5. Jul 20, 2010 at 6:54 AM
    ehawkins2002
    ehawkins2002 Member
    Pearl, Mississippi
    2010 PreRunner SR5
    Black Grillcraft grill, EGR vent visors, Husky liners
    I have 265/75 16 and no problems with rubbing. I had the tires on both stock wheels and aftermarket wheels 16 inch with 4.5 bs and still no rub. No problems here you should be good to go.
  6. Jul 20, 2010 at 6:58 AM
    Carlo
    Carlo Well-Known Member
    CA
    2010 Taco Magnetic Grey
    5100's all around, front at 0 with Ebiach springs up front; Wheelers 3 leaf AAL rear, Spidertrax
    I have a set of Destination AT's in 265/75/16 and they only rubbed when I was backing down my driveway and turning hard at the same time (my driveway is very steep). After a small lift they rubbed on the front of the wheel well, and I took my torch and heated up the black plastic lining of the wheel well and pushed it out about a 1/4 inch. Good to go. I love my tires and they look great on the truck. Since then I put a set of Ebaich springs up front and 5100's. I got about 1 5/8 inch lift.
