265/75 r16
Discussion in '4 Cylinder' started by jamejame, Mar 16, 2014.
  1. Mar 16, 2014 at 6:13 PM
    jamejame
    jamejame [OP] Member
    jamejame
    saint leonard md
    for now stock 2013 regular cab with a 3" lif
    hello everyone dont know much about tires and rims can someone tell me if nankang mudstar 265/75 r16 will fit on my stock rims? i have a 2013 regular cab 4x4 with 245/75 r16 stock tires and a 3" lift. thanks
  2. Mar 16, 2014 at 6:15 PM
    adanfon
    adanfon YNWA
    Adán
    Visalia, CA
    '11 Tacoma DCLB 4x4
    grillcraft, debadged, bilstein 5100's @ 0 w/ OME 886 coils and a 1/4" top plate spacer, rear has tsb springs and Wheelers HD progressive add a leaf. 1.25" spidertrax wheel spacers. Powder coated stock wheels. Tinted tails. Sport headlights. 20" led bar behind grille...
    Yeah they will
  3. Mar 16, 2014 at 6:17 PM
    coronacross
    coronacross Well-Known Member
    jeremy
    buckeye country
    07 taco lifted 4x4
    lifted, gear-swap, grill,tint,wheels-tires. arb locker, rabestos brakes.
    yes they will fit,,, the first number on a tire is the height of a tire,, the 2nd number is the with.. the 3rd number is the hole diameter or rim size.. the final number is somewhat the most important.. you cannot put a 16 in tire in a 17 inch wheel.. vise versa.. however even though you can put those tires on your wheels,, u will need a more experienced taco owner to let you know if they will fit on a stock taco... mine is lifted so I do not know how large of a tire fits on a stock unit.. hope that helps...
  4. Mar 16, 2014 at 6:17 PM
    jamejame
    jamejame
    saint leonard md
    the inch difference in width doesn't matter?
  5. Mar 16, 2014 at 6:19 PM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    Your new tire size is basically a 31x10.5 tire. They can go on a wheel as wide as 10" and as narrow as 8" or more. You most likely have an 8" wide wheel so you're GTG.
  6. Mar 16, 2014 at 6:20 PM
    coronacross
    jeremy
    buckeye country
    07 taco lifted 4x4
    its an inch diff in height not width bro...
  7. Mar 16, 2014 at 6:23 PM
    jamejame
    jamejame
    saint leonard md
    ok great. the data i got from google was the mudstar was one inch wider than my stock ones. they were boths 16s tho.
  8. Mar 16, 2014 at 6:27 PM
    jamejame
    jamejame
    saint leonard md
    was confident if they fit on the rim they would fit on the truck just was unsure about the width.
  9. Mar 16, 2014 at 6:27 PM
    jamejame
    jamejame
    saint leonard md
    thanks guys...again
  10. Mar 16, 2014 at 6:37 PM
    jamejame
    jamejame
    saint leonard md
    and i guess nobody has anything bad to say about the mudstars? one of the cheaper mud tire i could find...
  11. Mar 17, 2014 at 11:45 AM
    azreb
    azreb Geezer
    AZ mountains
    09 AC 4x4 stock
    camper shell, platform to replace rear seats.
    I have been considering 265/75s, too. My only concern is width--I haven't measured the gap between the top of the tire and the suspension yet. I know it is too narrow for tire chains on the front. If there is a width problem, that is where I would expect it to show.
  12. Mar 24, 2014 at 2:04 PM
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    Width/Ratio/Rim Size
    http://www.goodyearautoservice.com/content/content.jsp?pageName=TireSize
  13. Mar 24, 2014 at 3:35 PM
    choyt
    choyt Well-Known Member
    wayne
    new york
    2015 tacoma
    You won't have any problems even at stock height, I run them in the summer on O/R wheels with no issues ( 245/75/16 on steelies in the winter).
