265/75/r16's
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01Yota, Oct 13, 2011.
  1. Oct 13, 2011 at 12:28 PM
    01Yota
    01Yota [OP] Well-Known Member
    Jonathan
    Kentucky
    2003 toyota tacoma 4x4 Little monster truck
    Are they the same as 32's 10.50's 16's and can I tuck them under a regual cab tacoma 4x4? I'm pretty sure I can just asking before I spend a million dollars
  2. Oct 13, 2011 at 12:33 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    yes, i did but i remove my mud flaps
  3. Oct 13, 2011 at 12:34 PM
    01Yota
    Jonathan
    Kentucky
    Did they rub bad in the frount?
  4. Oct 13, 2011 at 12:38 PM
    01Yota
    Jonathan
    Kentucky
    So pretty much I'm adding .6 of a inch? Don't seem worth it to me
  5. Oct 13, 2011 at 12:39 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    using an american dimension a 31x10.5 15 is actually a 30.5
    a 32 is 31.5
    a 33 is 32.5
    etc
  6. Oct 13, 2011 at 12:40 PM
    Yoytoda
    Roland
    completely stock
    265/75 16 is equal to 32 10.5 16
    some 265/75s like duratracs or km2s are a true 32" tire
  7. Oct 13, 2011 at 12:41 PM
    01Yota
    Jonathan
    Kentucky
    Thats a relief to know I wasn't sure and didn't want to spend the money and get stuck with them if they didn't work
  8. Oct 13, 2011 at 12:43 PM
    Yoytoda
    Roland
    completely stock
    no sweat. i just know from using those sizes for shopping for 15s for my other trucks
  9. Oct 13, 2011 at 12:44 PM
    Yoytoda
    Roland
    completely stock
    what tires are you finding that use the inch system for a 16 rim?
  10. Oct 13, 2011 at 12:49 PM
    01Yota
    Jonathan
    Kentucky
    In the bfgoodrich a/t I put a 265/75R16 next to a 31x10.50x15 which is on my truck now and its just taller and a bigger wheel its all the same
  11. Oct 13, 2011 at 12:57 PM
    Yoytoda
    Roland
    completely stock
    oh in your original post you said 32x10.5x16
    which is a size ive never seen before. i thought you found a 16" tire that uses the american designation...
    a 265/75 16 is an inch and a half taller than a 31x10.5
    265/75 is a 32" usually
    a 31 is a 30.5 so 1.5" difference .75" in ground clearance
  12. Oct 13, 2011 at 1:17 PM
    01Yota
    Jonathan
    Kentucky
    i never really thought tires could be confusing but they can be would a 32x11.5x15 fit without a lift? im just trying to squeeze the biggest tire i can
  13. Oct 13, 2011 at 1:19 PM
    Yoytoda
    Roland
    completely stock
    265/75 16
    ive never seen a 32 10.5 15
    edit a 32 11.5 might be too wide
  14. Oct 13, 2011 at 1:23 PM
    01Yota
    Jonathan
    Kentucky
  15. Oct 13, 2011 at 2:12 PM
    01Yota
    Jonathan
    Kentucky
    I ment 32x10.50xr15 I would of edited my previous post but I'm on my phone
  16. Oct 13, 2011 at 6:23 PM
    bivey
    bivey Well-Known Member
  17. Oct 13, 2011 at 10:37 PM
    01Yota
    Jonathan
    Kentucky
    Well I feel about as stupid as a boxs of rocks now I guess before I go on tacomaworld I should sleep after a 12 hour shift
  18. Oct 13, 2011 at 10:57 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Don't worry, don't feel stupid! I get all mixed up with the numbers too as I'm sure others might too. That's the cool thing about this place. We learn so much. :)
  19. Oct 13, 2011 at 10:57 PM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
  20. Oct 14, 2011 at 12:02 PM
    pigger
    pigger Well-Known Member
    Greg
    Applecookie
    04 tacoma 4x4 reg cab
    Detroit True-Track rear limited slip, steering rack bushings, shell, SAF decals, Wheelers 5-leaf & Bilstein 5100's, some nice LED lights from Chris, older-than-dirt owner
    I run 265/75-16's on my non-lifted gen 1 reg cab; no rub even when wheeling hard.
