265/75R16 let's see them
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacofromthesipp, Jun 27, 2016.
  1. Jul 2, 2020 at 12:00 PM
    #301
    SmokeyTacoAZ
    SmokeyTacoAZ Well-Known Member
    2018 DCSB TRD 4x4 OR
    Same here on all counts. I don't really see the need for 285s and don't want to have to spend $$$ to regear so I'm aiming for a 1" lift and keeping 265s. I have other long term plans that may require new leaf springs anyway though....
  2. Jul 2, 2020 at 1:13 PM
    #302
    Blackbeard83
    Blackbeard83 Well-Known Member
    Sam
    Massachusetts
    2020 TRD Sport 4x4 ACLB MBM MT
    currently stock
    This. Though I think a small lift like 2" or lower you are ok if done right. My Jeep TJ is lifted 2.5" suspension and it has been fine with over 200,000 miles on it. I did the lift at about 30,000. The only issue I had so far from it is U joints going early from the heavy MT tires...
    The only big issue with the stock Tacoma suspension is that the rear is only designed for about 300 lbs consistent max load. So I may upgrade the suspension because of that. But I dont want to be over 2". I just want to be able to fit 265/75/16 tires.
    SouthernFried[QUOTED] likes this.
  3. Jul 2, 2020 at 1:15 PM
    #303
    331taco99
    331taco99 New Member
    Richmond VA
    Thinking about adding this to my sr5
  4. Jul 3, 2020 at 12:49 PM
    #304
    Taco821
    Taco821 Well-Known Member
    You got anymore pics of your setup? I have the same truck and am thinking about the 265/75r16 duratracs but I am super indecisive. Suspension completely stock?
  5. Jul 3, 2020 at 1:05 PM
    #305
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    Yes, the suspension is completely stock, I have had it off road a number of times and no rubbing, even when articulated to the point of wheels almost off the ground. I have cranked the wheels lock to lock without any rubbing either. I do believe that the OR has an inch higher lift stock, bit with all the space, I don't believe it would make a difference on the SR5 model, but would do a search to see if there are others with the SR5 to confirm.
  6. Jul 3, 2020 at 1:45 PM
    #306
    renlo
    renlo Well-Known Member
    2019 TRD OR 4x4 DBSB A/T
    How do you like thise atp’s? Considering those or at3 4s
  7. Jul 3, 2020 at 2:13 PM
    #307
    Texas2252
    Texas2252 Well-Known Member
    2009 Black Tacoma SR5 Prerunner
    Honestly by far the best tire I've ever used. I bought the truck in Jan 2017. Put 100k miles on them and still have great tread left. I think I have a ply used for towing that's the reason why they have lasted long cuz I hardly ever tow. They do great in the mud and sand. I got them at discount tire, I think I paid $1200 for 5 tires with road hazard warranty. Mount and balanced. Best decision ever made!
    renlo[QUOTED] likes this.
  8. Jul 3, 2020 at 3:33 PM
    #308
    stevecb63
    stevecb63 New Member
    2016 Red Toyota Tacoma TRD Off Road
    265/75R16 General Grabber ATX tires, 2 inch Rough Country leveling kit, trd pro grill and ditch lights.
    265/75r16 General grabber atx tires, 2 inch leveling kit from rough country in the front with nothing lifting the rear. I plan on a 1in block for the rear soon but also added the trd pro grill and ditch lights
  9. Jul 3, 2020 at 5:42 PM
    #309
    Taco821
    Well I think ill be going with the 265/75's. Your setup looks great!
  10. Jul 3, 2020 at 5:53 PM
    #310
    Interbeing
    Austin, TX
    geoyota760 and Blackbeard83 like this.
  11. Jul 4, 2020 at 4:01 PM
    #311
    Taco/Jäger
    Taco/Jäger Well-Known Member
    2016 Tacoma SR 2wd
    How do you like the X-ATs? How much lift do you have?
  12. Jul 4, 2020 at 4:53 PM
    #312
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    I like them bro. Good for light off-roading. Good in the rain also. I have 5100’s all around 1.5” front lift rear 1.5” aal.
  13. Jul 4, 2020 at 6:50 PM
    #313
    SmokeyTacoAZ
    What AAL did you install?
  14. Jul 4, 2020 at 7:05 PM
    #314
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Wheelers aal
  15. Jul 4, 2020 at 7:31 PM
    #315
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    The ubiquitious 265/75 KO2.
    [​IMG]IMG_2575 by Mike M, on Flickr
    [​IMG]IMG_2567 by Mike M, on Flickr
    Sometimes I'd like to try a 285, but I'm 99% sure for these specific wheels I'd need to look at a CMC / pinch weld work and that's not something I want to go near. These fit with zero issue, and zero issue is good.
    I'm upping to a 265/70-17 snow tire this year on FJC steel wheels painted silver. I would love to do the 275/70-17 size I've seen people do, or even a 255 and whatever equivalent aspect ratio to get a 33" tire, but the same thing, I don't want to risk having something rub.
  16. Jul 31, 2020 at 2:45 PM
    #316
    dc welding
    dc welding Well-Known Member
    Dan
    Swansea Mass
    15 DCSB TRD Sport BRM / 2002 AC SR5
    Goodyear Duratracs..... thanks to this thread. It helped me pick this tire and I’m totally happy with them. C-load.
  17. Jul 31, 2020 at 3:27 PM
    #317
    Taco/Jäger
    2016 Tacoma SR 2wd
    Are those Standard Load or E Load?
    71tattooguy likes this.
  18. Jul 31, 2020 at 3:41 PM
    #318
    Taco/Jäger
    2016 Tacoma SR 2wd
    Is that the E Load or SL?
  19. Jul 31, 2020 at 4:42 PM
    #319
    Millhouse516
    Millhouse516 Traveling by Tacoma
    San Diego
    Silver 2019 DCSB SR5
    5100's - Icon AAL - RTT - DIY Awning - DIY Mods
    They are the lighter 116T C load version.
  20. Jul 31, 2020 at 9:00 PM
    #320
    Mike G
    Mike G Well-Known Member
    2020 SR5 Tacoma DCLB 4x4 Red
