265/75R16 let's see them
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacofromthesipp, Jun 27, 2016.
  1. Jul 31, 2020 at 10:53 PM
    #321
    renlo
    renlo Well-Known Member
    2019 TRD OR 4x4 DBSB A/T
    Just got these today as well. AT/3 4s in sl rating.
  2. Aug 3, 2020 at 3:53 PM
    #322
    TheBeers
    TheBeers Active Member
    Jake
    North Woods NH
    20 WHT TRD OR DCSB
    Hopefully this is a good spot for this question... Would 265/75/16 be a good fit on 16x8 0 offset, and would that setup rub on stock? Also would it be advised to go with E load rating if I'm adding a Diamondback SE cover and rock siders? Not sure if i want to lift or add armor at this point. Just trying to make it more offroad worthy but still ride nice on the daily.
  3. Aug 4, 2020 at 4:40 AM
    #323
    Brownie_Man
    Brownie_Man Well-Known Member
    Maine
    2019 Off Road
    Some people have had to remove mudflaps with this setup because of minor rubbing. But, general consensus is you should be ok. There is a little variance in the height of the "same sized" tires which may contribute to different experiences for people. Many people run E loads. Probably not as smooth for a daily driver, but certainly gives some more protection off road. Maybe comes down to personal preference on what you accept for ride quality.
  4. Aug 4, 2020 at 6:18 AM
    #324
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    With the 16x8 0 offset on stock height you will rub a little running 265/75/16 tires. I'm on 2020 TRD Pro wheels and 265/75/16 and I get a small rub on occasion going in and out of a driveway at full turn. Nothing at all during normal driving. No need for E rated tires, save your money and gas mileage.
    TheBeers[QUOTED] likes this.
  5. Aug 4, 2020 at 6:36 AM
    #325
    bnv
    bnv Boy I say, use CRAWL to sneak up on that dawg!
    Bruce
    San Diego
    2016 Access Cab TRD Off Road 4X4 Quick Sand
    Kings adj, TC UCA, Zeon 10s, PB bumper, BD 30" light bar, BD cornering lights, Line-X Grill, Wheels, Tires Duratracs, tint, gate lettering, glove box lettering, ARB compressor
    Duratracs, I like em!
    The only rubbing for me, is when I think about them in the shower.
  6. Aug 4, 2020 at 2:51 PM
    #326
    renlo
    Does it rub on the mudflap or wheel well. Im jist waiting for the same spec wheels but will be adding a .75” spacer thats gives a 1.5” lift.
  7. Aug 4, 2020 at 3:11 PM
    #327
    texas angler
    texas angler Well-Known Member
    Texas Hill Country
    20 OR
    No rubbing for me...no lift either. 265/75/16 GY UTs on 16x8 0mm offset Methods.
  8. Aug 4, 2020 at 7:14 PM
    #328
    Chip_311
    Chip_311 Well-Known Member
    Brian
    NJ
    2017 DCSB OR
    BFG KO2s Pro Grille Pro Skidplate Pro Fox Suspension DShackles F & R CaliRaised LED Bumper Baja designs S2pro / S1 CaliRasied Off-road Sliders Waterport R4T Arm Skids RCI Skids Weather tech Visor Front Camera SCS Wheels Rear Bumper Covers Maxtrax Recovery Meso Gas Hole/Turn Signals Pop n Lock Kit Extended Rear Breather Expedition Essentials TPAM Midland USA Comms Clazzio Leathers Victory 4x4 Mollie Garmin Tandem Mountain Hatch Bestop2 Thule Evo Rack
    Scs Stealth 6
    Blackbeard83, Alden, FashTaco and 2 others like this.
  9. Aug 4, 2020 at 8:53 PM
    #329
    SSG (03)TACOMA
    SSG (03)TACOMA SSG TACOMA
    2023 DOUBLE CAB V6 TRD SPORT 4x4
  10. Aug 5, 2020 at 4:59 AM
    #330
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    I don’t have mudflaps.
  11. Aug 5, 2020 at 5:11 PM
    #331
    dc welding
    dc welding Well-Known Member
    Dan
    Swansea Mass
    15 DCSB TRD Sport BRM / 2002 AC SR5
  12. Aug 5, 2020 at 5:50 PM
    #332
    Hawktane
    Hawktane Member
    Tom
    Half Moon Bay, CA
    2018 TRD Off-road
    Just got some GY Ultra Terrains. Screen Shot 2020-08-05 at 5.49.36 PM.jpg IMG_5938.jpg
  13. Aug 5, 2020 at 6:51 PM
    #333
    SoCali_Guy
    SoCali_Guy Well-Known Member
    California
    TRD OFF ROAD
    E Load Rated
  14. Aug 6, 2020 at 5:06 AM
    #334
    Taco/Jäger
    Taco/Jäger Well-Known Member
    2016 Tacoma SR 2wd
    I’m looking at running those same tires. What air pressure are you using front and rear?
  15. Aug 6, 2020 at 10:51 AM
    #335
    SoCali_Guy
    California
    TRD OFF ROAD
    Sorry late reply.. I run them at 33/34.. heat up to 37.. they feel better & wear evenly at that PSI ... best decision to go w the E rated over the P metric
  16. Aug 21, 2020 at 7:07 PM
    #336
    Mitch65
    Mitch65 Well-Known Member
    Hey Scott! I have the same exact decel vibrations. Did the drop kit fix your vibes? What kit did you order? Mines lifted 2.5” all around. Thank you
  17. Aug 21, 2020 at 7:13 PM
    #337
    Harmon
    Harmon Well-Known Member
    Jacksonville
    2020 Tacoma SR V6 4X4
    265/75/16 BFG KO2's Front ARB Air Locker
    Goodyear Duratracs 265/75/16 C Load. So far so good. A bit of a hum at lower speeds nothing that is to bothersome (Its a truck after all).
    No rubbing, stock suspension for now, but not for long.
  18. Sep 1, 2020 at 10:31 AM
    #338
    Scott W
    Scott W Well-Known Member
    Scott
    Saranac Lake, NY
    2018 Tacoma TRD PRO. Calvary Blue.
    TRD Performance Air Intake. TRD Shift Knob. KTJO 4X4 Red TRD Push Button Start/Stop. Calvary Blue FOBIK by AJT Design. 12volt Solutions Remote Start with CAR:LINK Smartphone Remote Start and GPS app. Sprint Booster V3 Throttle Response Enhancer. AFE Silver Bullet Throttle Body Spacer 46-38010. 2" Supreme Suspension Lift Kit. TOYO 265/75R16 Open Country A/T2. EGR Matte Black In-Channel Vent Visors. REK GEN Offroad Mud Guards. AMP RESEARCH Power Steps. JDMastar 10000lumes LED Low Beam Lighting T1. JD Mastar Raptor LED Lighting. TRUXEDO Tonneau Cover.
    sorry for late reply. I installed an Old Man Emu Carrier Bearing Drop Kit and it worked great. Available at Extreme Terraine.com
  19. Sep 1, 2020 at 11:30 AM
    #339
    LstMinutePanic
    LstMinutePanic Well-Known Member
    Colorado
    2018 Black Tacoma OR DCLB AT
    Me too! Drove out past Crystal Mill to Lead King Basin this weekend, and the Ultraterrains performed like champs! Big sharp rocks, wet slick rocks, a little mud, and gravel; I was really happy with them. It ended up raining/snowing, and I was worried about their traction on the way out, but zero issues. Depending on their long-term durability, these may be the best all around tire for me. 265/75/16 SL, stock suspension.
    I see a lot of smack talk (but not much actual evidence) about problems with Duratrac and Ultraterrain sidewalls, but I had zero problems during the 45,000 miles that I had C-load Duratracs driving around trails in CO and UT. Hopefully the Ultraterrains hold up as well as the Duratracs did.IMG_20200828_182633.jpg IMG_20200822_185557.jpg IMG_20200822_185530.jpg
  20. Sep 1, 2020 at 6:01 PM
    #340
    RNO_TACO
    RNO_TACO Well-Known Member
    Brent
    Roseville, CA
    2019 Cement Grey Tacoma TRD Off-road 4x4 DCSB
    A.R.E. Topper with victory topper rack, blacked out exterior emblems, star armor side steps, TRD CAI, TRD Pro exhaust, Method MR305 NV 16in Rims, TRD PRO front grill, Meso coin holder, TRD Pro skid plate, Kings 2.5 coilovers with remote resis front and rear, OME HD Dakar’s, ECGS, LT285/75R16 KM3s, Dirt king UCAs, Meso gas cap holder, Meso blacked out interior kit, TRD start/stop red button, AVS low profile window guards, AVS low profile hood protector, Full LED upgrades inside and outside, decked bed storage system. And I’m sure there’s more I’m missing lol
    100k on a set of tires and still good tread left huh? Wow. That’s insane. I’ve never even got close to that type of mileage for any tire and I’ve had them all (MT/AT/HT etc) May have to consider these in the future. Glad I found this post. Take care.
