265/75R16 let's see them
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacofromthesipp, Jun 27, 2016.
  1. Oct 30, 2020 at 7:14 PM
    #681
    RNO_TACO
    RNO_TACO Well-Known Member
    Brent
    Roseville, CA
    2019 Cement Grey Tacoma TRD Off-road 4x4 DCSB
    A.R.E. Topper with victory topper rack, blacked out exterior emblems, star armor side steps, TRD CAI, TRD Pro exhaust, Method MR305 NV 16in Rims, TRD PRO front grill, Meso coin holder, TRD Pro skid plate, Kings 2.5 coilovers with remote resis front and rear, OME HD Dakar’s, ECGS, LT285/75R16 KM3s, Dirt king UCAs, Meso gas cap holder, Meso blacked out interior kit, TRD start/stop red button, AVS low profile window guards, AVS low profile hood protector, Full LED upgrades inside and outside, decked bed storage system. And I’m sure there’s more I’m missing lol
    36 here on my KO2. No issues.
    gabbo2112 likes this.
  2. Oct 30, 2020 at 7:56 PM
    #682
    6MTlittletruck
    6MTlittletruck Active Member
    2020 White Tacoma TRD Off-road
    I’ve got mine right around 33/34 cold. Wondering if I should bump up a few pounds
  3. Oct 30, 2020 at 8:05 PM
    #683
    trailbound
    trailbound Well-Known Member
    Rob
    Surprise, AZ
    2016 DCSB TRD OR 4x4
    36psi in mine. I'm towing 3000lbs next weekend and am going to bump them up...thinking 40 to 45psi but I'm not sure?
  4. Oct 30, 2020 at 8:31 PM
    #684
    mdelosrey
    mdelosrey Well-Known Member
    I use this website to calculate tire baseline pressures when switching sizes/load ratings, I then adjust depending on how they wear/perform on and off road.
    Ferrell and ohcjam like this.
  5. Nov 1, 2020 at 3:02 PM
    #685
    OvrlndBigAl
    OvrlndBigAl Well-Known Member
    Alex
    Some where in Idaho!
    Cement 2019 TRD OR DCSB
    Just a Snug Top with Sportsman’s package 1 inch lift and 265/75-16 Duratracs.
    Well, I’ll probably need tires before the end the year and I really wanted Duratracs. I was planning on 265/75-16 in load range C for my all stock TRD OR but I might get the KO2 instead. I drive a lot and frankly I don’t get out and wheel much like I did in my Jeep days. Problem is I can only find load range E in that particular size. How are they over stock tires? I really don’t need such highly rated tires and frankly if the ride was at least stock or smoother I wouldn’t complain. I’m just afraid if I run E rated tires they’ll feel harsh, especially on our fine pot hole ridden California roads. Maybe running them 32-35 psi and the slightly bigger sidewall than the stock tires will help but what’s the real world say? They decent or harsher than factory?
    Thanks!
    T-yoda likes this.
  6. Nov 1, 2020 at 3:32 PM
    #686
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    I run “E” ko2’s and been running them at 32. Winter is starting to set in and bumped up to 36. Definitely feels firmer. Only thing I could say is do the “c” in the factory size. 265-70-16 unless you do a different tire all together I’d you don’t want the harshness .
    OvrlndBigAl[QUOTED] likes this.
  7. Nov 1, 2020 at 3:41 PM
    #687
    OvrlndBigAl
    Alex
    I could, I just wanted the minuscule +1 on the tire size damn it. My main concern with the Duratracs is I commute over a mountain range every day I feel like those are just going to get all choppy and wore out. I rotate my tires every 5k with my oil changes but certainly the KO2 would probably suit my driving better. I feel like the factory size just looks dorky in the wheel well. Once we move in a year I’ll probably re assess and lift my truck/get better tires next time. Until then it’ll be what you mentioned, probably factory KO2 in the C flavor or perhaps I’ll get a +1 Duratrac.
    For those with the Duratracs, do they get noisy over time or do they wear nicely?
    T-yoda[QUOTED] likes this.
  8. Nov 1, 2020 at 4:01 PM
    #688
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    I have a buddy that runs the duratracs... a little more hum then the ko2’s but got noisy the more miles driven on them.
  9. Nov 1, 2020 at 4:02 PM
    #689
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    What about the general grabbers?
  10. Nov 1, 2020 at 4:12 PM
    #690
    OvrlndBigAl
    Alex
    I haven’t really looked into those honestly, maybe I should look at Coopers too. Coming from Jeeps I guess I’m just biased to what I’m used to seeing. Frankly if it’s not a 33/35/37x12.50 it just seems odd. lol
    I actually really like the factory 16 inch wheels but I could see why so many folks go 17. Looks like better options.
    Blackbeard83 and T-yoda[QUOTED] like this.
  11. Nov 1, 2020 at 4:23 PM
    #691
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    I sometimes look to hard into tires that it’ll drive me nuts. Find a load range you want to run and then find a tire that fits your needs
  12. Nov 1, 2020 at 5:05 PM
    #692
    flatus
    flatus Well-Known Member
    biloxi,ms
    2020 TRD OR DCSB 4wd Auto
    Waiting for bank account to grow
    The OEM size KO2’s are also E rated so that’s not an option for you. C rated can be had for 17in rims (265/70/17) but not 16in rims.
  13. Nov 2, 2020 at 10:16 AM
    #693
    mdelosrey
    Just got back from a trip up and down The Lost Coast. Tires were decent off road and minimal noise on road. I can’t say anything about increased noise over time as the tires are still fairly new. As far as looks, I think these metric tires look skinny but that’s because maybe I’m used to seeing 33x12.5 on my Jeep. Good luck on your search!
    edit: Duratrac C-load 265/75/16 on F5’s -25
  14. Nov 2, 2020 at 10:25 AM
    #694
    Toyota09
    Toyota09 Well-Known Member
    2016 Tacoma TRD Off-Road Inferno
  15. Nov 2, 2020 at 4:06 PM
    #695
    Chris1121555
    Chris1121555 Well-Known Member
    East Coast
    2017 Infeno TRD OR Manual
    -Toytech BOSS 2.0 Aluma Series lift w/ AAL (2") -265/75R16 BFG AT KO2's -Plastidipped TRD OR Wheels w/ Red TRD Center cap -LED Head/Fogs -Interior LED lighting -Rigid Industry Ditch Lights -Black OEM Grill (Painted) -Westin Grill Guard -Copy Polymer Shfit Knob (M/T) -Tonneau Cover, Tri-Fold. (*Looking to sell or trade for Rollup*) -Kicker CS speaker upgrade -Kicker Hideaway 8" subwoofer
    BFG A/T Ko2's
  16. Nov 2, 2020 at 4:17 PM
    #696
    St0rm-Tr00per
    St0rm-Tr00per Well-Known Member
    SoCal
    2018 TRD OR 4X4 DCLB - Super White
    “Semi-Pro”/“PrOff-Road”
    Just a curiosity about this post ... why do so many people post pictures of their tires but not the brand? In many pics it’s very hard to tell even when zoomed in.
  17. Nov 2, 2020 at 4:20 PM
    #697
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    It normally pretty easy to pick out what tire they’re running.... but I hear ya
    Cows Have Claws likes this.
  18. Nov 2, 2020 at 4:37 PM
    #698
    Chris1121555
    East Coast
    Fixed mine for ya. I hate that too. :thumbsup:
  19. Nov 2, 2020 at 4:58 PM
    #699
    zacncheese
    zacncheese New Member
    Zach
    2020 Toyota Tacoma OR
    Bilstein 5100 (4th notch) 265/75R16 Toyo Open Country AT3 Method Race Wheels 704
    265/75R16 with Bilstein 5100 at 4th notch
  20. Nov 2, 2020 at 5:10 PM
    #700
    OvrlndBigAl
    Alex
    Hard to tell but those factory OR wheels with black decals? Looks good. Any lift or factory height?
    Chris1121555[QUOTED] likes this.
