265/75R16 let's see them
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacofromthesipp, Jun 27, 2016.
  1. Mar 9, 2021 at 6:42 PM
    #1101
    gabbo2112
    gabbo2112 Well-Known Member
    New York
    2020 TRD Off Road
    Year one and many mods here it sits on Dakar medium leafs and 5125’s in the rear with 5100’s and 885 OME coils with 3/8” inch spacers and camburg uca’s. Oh and KO2’s CB47BB80-EF21-46A2-97EA-06DEBB4809B5.jpg
  2. Mar 13, 2021 at 8:01 AM
    #1102
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    Who mounted your tires? See that red and yellow dot on the sidewall? The red dot is supposed to be aligned with the tire valve.
    9mmMike and rubiconjp like this.
  3. Mar 13, 2021 at 8:02 AM
    #1103
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I was thinking the same.
    9mmMike likes this.
  4. Mar 13, 2021 at 9:34 AM
    #1104
    pjmariner
    pjmariner Active Member
    I got them done at Mavis/NTB. U guys sent me down a rabbit hole.... but I went out and looked the tires do not have an excessive amount of weight on them, and I have had the truck up to 85, and I have had no vibration at any speed. Here is a quote from tire rack...
    “There was a time when the valve stem hole on standard wheels indicated the optimum place to which the tire should be match mounted. However, with the advent of styled, steel wheels and aluminum alloy wheels, the stem position evolved into an aesthetic issue rather than being a uniformity indicator. Add to this the probability of wheels retaining their original runout after thousands of miles of use and you can understand that simply mounting the tire so the colored dot is at the valve stem is no longer required practice.
    We have found that the only way to accurately match mount replacement tires on used original or new aftermarket wheels is to use Hunter tire balancers which have the ability to measure wheel runout and tire force variations under load before the tire and wheel are installed on the vehicle. Using these machines, a colored dot might be positioned anywhere on the wheel relative to each wheel's runout measurement. In the end, the markers have little, if any, relevance when replacement tires are installed.”
    https://m.tirerack.com/tires/tiretech/techpage.jsp?techid=17
    shady 74, texbaz and rubiconjp like this.
  5. Mar 13, 2021 at 10:30 AM
    #1105
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    I put my foot in my mouth here. When i had mine installed a few months ago, i asked them if they knew about the dots. They said yes. I was just putting air in my tires and noticed they lined up the yellow dots with the air valves instead of the red. And thats a toyota dealer.
  6. Mar 13, 2021 at 10:32 AM
    #1106
    eddiezee
    eddiezee Member
    2020 Cement Tacoma TRD OR 4WD
    Anyone running AR172 baja Wheels on their 265/75/16's with no lift?
    Want to pull the trigger at 0 offset, but heard that they rub on calipers, can anyone confirm?
    T-yoda and Paul466 like this.
  7. Mar 13, 2021 at 10:41 AM
    #1107
    530Taco
    530Taco Gone fishin'
    Adam
    Old Hangtown, CA
    '21 DCSB OR MT Cement
    265/75 Evolution M/T on SCS F5s 16x8 0 offset
    No rubbing, stock suspension, zero trimming.
  8. Mar 13, 2021 at 8:38 PM
    #1108
    RBG Taco
    RBG Taco New Member
    2020 Cement TRD OR 4X4
    Bilstein 5100, OME 2885 lift. Deaver AAL. BFG KO2
    Went with 265/75 ko2s , 5100’s, OME 885s and Deaver AAL. Resulted in 2” all around. Thanks @HeadStrong Off-Road
    Mr. King, gabbo2112, T-yoda and 4 others like this.
  9. Mar 13, 2021 at 8:58 PM
    #1109
    gabbo2112
    New York
    2020 TRD Off Road
    Great looking truck man love that colour, I have the same set up and love it! Welcome to TW :hattip:
    T-yoda and RBG Taco[QUOTED] like this.
  10. Mar 13, 2021 at 11:42 PM
    #1110
    RushT
    North Texas
    Not great pics, but I posted these over in the Toyo thread. New shoes today.
    B4CF3CED-913C-4FB2-A960-288942CF2465.jpg 413C1113-3D7E-41DF-B923-F05A077B7BA9.jpg
    Polythemus, JakNY, Rupp1 and 6 others like this.
  11. Mar 14, 2021 at 8:45 AM
    #1111
    GlazedGerbil
    GlazedGerbil New Member
    Kyle
    British Columbia
    2018 TACOMA TRD OFF-ROAD DCSB QUICKSAND
    Roof Racks Heritage Grill c/w Raptor Lights Bak Revolver X4 265/75/16 Toyo Open Country AT3 - Black Rhino Stadium Meso Customs Blacked Out Turn Signals Meso Customs Interior Chrome Delete Kit
    Installed the Toyo AT3’s and Black Rhino Stadiums over a year ago. Been great so far, gotten a bit louder on the road, but I like the hum so it’s all good.7FFAAA86-E136-413F-881A-0C0C1F02E361.jpgA42CA7F5-73C6-44CC-A3C3-4EA76DDFC40D.jpg
    Polythemus, hayjohn, RBG Taco and 3 others like this.
  12. Mar 19, 2021 at 6:06 PM
    #1112
    ghostleaf
    ghostleaf enjoy the ride
    Hawaii -> PNW
    2020 TRD OR DCSB 4X4
    freshly installed falken wildpeak 265/75r16
    545CF245-D4DB-4BC0-87EF-6F4DC37A14F1.jpg 32A91E7A-B307-4DCF-8611-2DEBA0A4B0A9.jpg
  13. Mar 19, 2021 at 6:51 PM
    #1113
    Stoked
    Stoked Not So Well-Known Member
    Jeff
    Celina, Tx
    2016 DCSB TRD OR
    Yokohama Geolandar M/T...no lift, no rub. Only 6 miles on them, but good so far.
    Fast1, CreoUCLA, rubiconjp and 4 others like this.
  14. Mar 19, 2021 at 9:45 PM
    #1114
    viclava
    viclava Well-Known Member
    Scott
    North Central Washington
    2020 Tacoma TRD Off-Road
    LED lights Eibach 2.5" coil and shock liift with 2" AAL W/2* shim in rear, RTT
  15. Mar 20, 2021 at 7:04 AM
    #1115
    JDPNW
    JDPNW Well-Known Member
    S. Oregon
    2021 DCSB TRD OR Cement KDMax-Pro
    Eibach 2.0,SPC UCA,ECGS,ATS 4/1 rear leaf,5.29
    Wildpeak's on black rhino stadium 16x8 -10 offset.
  16. Mar 20, 2021 at 10:28 AM
    #1116
    klharmon
    klharmon New Member
    Ultra terrains[​IMG]
  17. Mar 20, 2021 at 10:53 AM
    #1117
    viclava
    Scott
    Nice looking truck here..
    klharmon likes this.
  18. Mar 20, 2021 at 1:15 PM
    #1118
    psvines
    psvines Well-Known Member
    2016 SR5
    Awesome, finally found another Taco with the same wheels as mine.
    Smoothmove[QUOTED] likes this.
  19. Mar 20, 2021 at 1:56 PM
    #1119
    viclava
    Scott
    Looking at the mountains from out of my Taco garage..
  20. Mar 20, 2021 at 1:58 PM
    #1120
    Fullsendcf
    Fullsendcf Well-Known Member
    Craig
    SF - Bay Area
    '18 Cement TRD OR
    Eibach lift??
