265/75R16 let's see them
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacofromthesipp, Jun 27, 2016.
  1. Mar 7, 2023 at 5:33 PM
    #1321
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    Chalk tested my Mickey's at 30 cold front and 28 cold rear.
    Mbtstaco[QUOTED] likes this.
  2. Mar 7, 2023 at 6:04 PM
    #1322
    Joe Joe
    Joe Joe Well-Known Member
    Arthurdale, West Virginia
    2019 White OR DC MT
    ADM 2Lo Mod 3TPAM
    Cooper AT3 4s 265/75/16 I keep at 35 cold.
    Madimor and Mbtstaco like this.
  3. Mar 7, 2023 at 6:32 PM
    #1323
    Wadar
    Wadar Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
    Wonders never cease… just randomly stumbled across this thread.
    Running Method 701’s and Wildpeak AT’s.
    784544CA-67B2-4EA2-915E-148DC0F2DC70.jpg 52518DEB-AE43-4BB1-8C4A-3B2437989B83.jpg
    fasteddie23 and Road_Warrior like this.
  4. Mar 7, 2023 at 6:33 PM
    #1324
    Wadar
    Wade
    A few.
    Likely a different castor setting. Did your brother get an alignment after installing the new tires? That would be my first suggestion. Secondly you could try the heat gun if plan A fails.
  5. Mar 8, 2023 at 3:22 PM
    #1325
    TacoMeNow
    TacoMeNow Member
    2023 Tacoma OR 4x4
    So I'm 2 weeks away from receiving my 2023 Trail Edition. I know i want to go with the 265 over the 285 for power reasons while towing.
    But, what I'm looking to see is someone with the 265/75 setup with a 3in front 2 in back lift. its on its way currently and trying to decide if im going to keep or send back. Can anyone drop some pics?
  6. Mar 8, 2023 at 4:16 PM
    #1326
    bulldog
    SW MO
    2023 Pro
    2 1/2 in the front, not 3.
    jeremy5000 and Detailsmatter like this.
  7. Mar 10, 2023 at 2:06 AM
    #1327
    Detailsmatter
    Detailsmatter Member
    Grayson
    ‘19 Cement DCSB TRD OR 4x4 MT
    I’ve been running the 265/75/16 KO2’s about a year now. This was after 40k miles on the OEM tires. What were they? Wrangler Kevlar or something?
    Anyway, no rubbing with the stock height.
    Only thing… they kill gas mileage. I went from 18.5ish MPG to 15MPG if I’m lucky. I do sometimes think they look a bit dorky at the current ride height.. the 3:2 lift looks way cooler. I just gotta get my money out of this OEM suspension before a lift
  8. Mar 10, 2023 at 4:32 AM
    #1328
    TRP
    TRP Well-Known Member
  9. Mar 10, 2023 at 6:14 AM
    #1329
    Madimor
    Madimor Well-Known Member
    Scott
    Anchorage, AK
    2017 MGM TRD Off Road
    that’s where I have my LTs.
    Joe Joe[QUOTED] likes this.
  10. Mar 11, 2023 at 7:48 AM
    #1330
    Falcon016
    Falcon016 Well-Known Member
    2017 Magnetic Gray Metallic TRD Off-Road
    He went and got an alignment. Here is the sheet. He is still rubbing. Do you have a caster setting you would recommend setting them to? I never once rubbed when I had them on my truck but I do not have anymore alignment sheets.
  11. Mar 11, 2023 at 8:12 AM
    #1331
    CSVT
    CSVT Well-Known Member
    Ohio
    2021 TRD Pro
    what’s dorky about the look to you?
  12. Mar 11, 2023 at 7:17 PM
    #1332
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    Looks good to me - definitely not dorky IMHO - like the what you did to the center caps btw.
    Detailsmatter[QUOTED] likes this.
  13. Mar 11, 2023 at 7:52 PM
    #1333
    TacoMeNow
    TacoMeNow Member
    2023 Tacoma OR 4x4
    Thanks, Because of this i switched my order
    bulldog[QUOTED] likes this.
  14. Mar 11, 2023 at 8:02 PM
    #1334
    GatorBodine
    GatorBodine Well-Known Member
    Jay
    23' 4 cyl.
    E rated? Are the KO2's available in C rated in 265/75/16? C rated would be lighter, that's a big mpg hit
  15. Mar 11, 2023 at 8:06 PM
    #1335
    DrBarGnarLovesTacos
    DrBarGnarLovesTacos To Each His Own
    Orange County, CA
    2020 Cement TRD OR DCSB 4X4/Snugtop Camper
    265/75r16 Falken Wildpeak's SL load rating. She's in dire need of a suspension upgrade. Thinking of some Deaver U402 stage 2 or maybe even stage 3 at this point. I'm trying to decide between Fox 2.5 adjustable, Bp51's, or Dobinson MRR's.
    Detailsmatter likes this.
  16. Mar 11, 2023 at 8:10 PM
    #1336
    Detailsmatter
    Grayson
    No lift with bigger wheels looks a little toy truck. A lift helps fit the wheels to the truck. But beauty is in the eyes of the beholder. I’m probably just rationalizing a lift in the future
    burrito782 and CSVT[QUOTED] like this.
  17. Mar 11, 2023 at 8:12 PM
    #1337
    Detailsmatter
    Grayson
    Great point! Not sure on the rating. But I totally agree, increasing dynamic weight is a big killer to MPG and wear.
  18. Mar 11, 2023 at 8:14 PM
    #1338
    Detailsmatter
    Grayson
    Looks like a lot of fun could be had with that rig! Nice setup man.
  19. Mar 11, 2023 at 8:23 PM
    #1339
    DrBarGnarLovesTacos
    Orange County, CA
    Thanks brother! I've been debating whether I should get a Rooftop tent to go on top of the camper shell or sell the camper shell on here and get an all-in-one shell with a tent from say Topo Toppers or OVRLND Campers. I just love the look of the color-matched topper and dual prinsu roof racks. I slept in the camper shell for almost two months last winter roaming around Colorado snowboarding and it's a bit cold and uncomfortable but doable.
  20. Mar 11, 2023 at 8:30 PM
    #1340
    Detailsmatter
    Grayson
    well god dammit. I just bought the Leer 100XR with all the goodies. Had we talked two months ago, I may have saved some money buying your topper used . TBH bro, IMHO… your current set up is way cooler and has that OEM clean look. Also a little more stealth without the RTT. That being said, I’m sure there are literally HUNDREDS of dudes who would love to buy that shell off you! You’re winning either way
