265 to 285 Mileage/MPG Error Calc
Discussion in 'Wheels & Tires' started by Relik, Aug 1, 2011.
  1. Aug 1, 2011 at 2:04 PM
    Relik
    Relik [OP] Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    Hey all,
    I'm about to make the jump myself to either 275 or 285 and I'm interested in BFG All terrains. As many I am afraid of mpg loss so I compared all the numbers and here is the mileage error I have calculated.
    After MUCH research on here, I think people forget their mileage is off, hence why the MPG loss is complained about/why some see big drop in mpg. The tire is bigger, achieves more distance in same amount of rotations hence why mileage is portrayed less than actual=mpg off.
    From my calcs the switch leaves you at about -2MPG error just from the circumeference difference
    (Dunlop GrandTek AT20 265/65/17 to 285/70/17 BFGs).
    Now the weight also adds mpg loss ofcourse, but now it seems considerably less if the geometric loss noticed is only perception....for ex. if the ones who said they dropped to 15mpg after switch (from 18-20mpg previously), it was actaully 17mpg....etc....
    Thoughts?
  2. Aug 2, 2011 at 11:51 AM
    Relik
    Eddy
    Thousand Oaks, CA
    No thoughts? :D
  3. Aug 2, 2011 at 12:10 PM
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    Wet Okole's (front & rear), Weathertech Floormats (front & rear), cheap tailgate theft mod, extra d-rings, low profile toolbox (flat black), Thule Roof Rack (58" load bars), Thule Ski/Snowboard Roof Rack, Blacked Out Badges, Fishing Bobber Trailer Ball Cover, AVIC-X930BT w/ XM & steering controls, 5100s All Around (front set at .85), Eibach Coils, Rear TSB, rear AAL, LR UCAs, Toytec Diff. Drop, Mudflap Delete, Tailgate Reinforcement, Spidertrax (all 4), 285 Nittos, Rear Diff Breather Extension, TRD Exhaust, Powered Rear Sliding Window, DeeZee Bedmat, rear-view anytime mod, trailer bracket relocate, fog light anytime mod, redline hood struts, Satoshi with Homertaco Custom TRD Mesh, Hella 500s behind the grill, Brighter Reverse Lights
    how does this factor in with my current speedo reading high? right now i'm 1-2 high around 30 mph and around highway speeds it gets as much as 4 off. This i've seen vs GPS's and radar signs so i doubt they're all mis-calibrated like my speedo is. Not sure if it ties into the odometer or not.
    i'm about to switch to 285s so i sure hope you're right since i'm getting about 18-20 with my normal drivin now. good work on the calculations man.
  4. Aug 2, 2011 at 12:19 PM
    AuburnTaco
    AuburnTaco Active Member
    Dan
    Auburn
    Black 2010 4x4 SR5 DC
    Wind deflectors, bug and stone deflector, RollBak Tonneau Cover
    I recently upgraded form the stock 245's to some general grabber AT2's at 285/75R16. I went to the dealership and had them change the odometer/speedometer to accuractely reflect the larger tire size. I was getting about 21 mpg with the 245's and now i'm getting about 16 mpg with the 285's. I have no idea how accurate my speedo actually is.
    You need to factor in for frictional losses as well.
    Also, I have quite the lead foot and I sit in stop and go traffic which might not be a good comparison for the change in mpg
  5. Aug 2, 2011 at 12:26 PM
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    i knew i could go to the dealership to get the speedo adjusted for the bigger tires but since it came from the factory reading low for the stock tires i figured that's pretty much a lost cause. some people have said their speedo actually starts to be about dead on with the change from 265 to 285s.
    i might have to get a scangauge or ultragauge to show me my MPGs just to make sure i don't get a lead foot
  6. Aug 2, 2011 at 12:26 PM
    mxnborder
    mxnborder Well-Known Member
    Santa Barbara
    05 4x4 sport - black on black on black
    DR coilovers AAl 285 kelly safaris lightbar/skidplate need more!
    nice writeup where did you find that chart deal? i always wonder what my actual mpg is i usually calculate about 17ish with my 285's but know its off.
  7. Aug 2, 2011 at 12:45 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    My speedo is about 5mph at highway speeds (70ish)
  8. Aug 2, 2011 at 1:22 PM
    Relik
    Eddy
    Thousand Oaks, CA
    I calculated it all using data from tire rack, comparing the difference in revolutions per mile of each tire to stock.
  9. Aug 2, 2011 at 1:24 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
  10. Aug 2, 2011 at 1:32 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    That doesn't take into account rotational inertia, which is the big player here. Not only is the tire heavier, but now the radius is larger.
  11. Aug 2, 2011 at 4:57 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    Yeah, I agree, that is definitely true in a lot of cases.
  12. Aug 8, 2011 at 6:56 PM
    jgang
    jgang Well-Known Member
    Use this. Plug in factory size, then aftermarket size. The difference in diameter will give you the factor to multiply your odometer reading by when you check your gas mileage. I.e., factory 265/65/17 vs aftermarket 265/70/17 is a difference of + 3.4%. Multiply that (1.034) by your odometer reading and you get your actual mileage traveled. Double check it with the figures on the site....divide the actual reading by the speedo reading and you'll get 1.034. I've verified this formula with my GPS a dozen times and it's spot on. No need to mess with "rotational weight" as it's a non-factor in calculating actual road mileage. It's important if you're just running a bunch of figures for kicks, but for real world calculation of distance traveled, it's irrelevant. A mile traveled is a mile traveled, whether it's on "heavy" 285s or "lighter" 265s. The rotational weight may effect your fuel mileage, but has no bearing on a distance traveled calculation when switching tire sizes.
    Love that Excel chart OP!
  13. Sep 14, 2011 at 3:59 PM
    Srpat
    Srpat Active Member
    Shawn
    SE Wisconsin
    07 Tacoma DC SR5 TRD
    Figure this is as good a place to ask as any. 285's will cause the engine to have to work harder with the extra resistance, but with my 07 TRD 6 speed manual, would I increase highway mpg by increasing tire size?
    Those of you with this tranny know that the sixth gear is kinda high on the manuals...that's why the autos get a 1 mpg better rating than we do. Having taller tires would be like regearing the tranny, wouldn't it? Anyone see this that went with 285s?
  14. Sep 14, 2011 at 4:39 PM
    Tacomadude89
    Austen
    California
    In a lot of cases, yes, the larger tires can cause a little better mpg on the highway due to the lower rpm's. A lot of people have reported that.
    Of course, many other factors come into play such as a headwind or climbing a grade which change everything.
  15. Sep 14, 2011 at 5:48 PM
    mxnborder
    Santa Barbara
    lets all put 37's on our tacos :quickdraw:
  16. Mar 24, 2012 at 10:03 AM
    xgalvanxgx
    xgalvanxgx seymour butts
    Gerardo
    OC (Lake Forest) California
    TRD Off-Road BlackSandPearl 07 PreRunner
    DTF Race Kit with 2.5 x 10 Kings, DMZ SUA rear with 16" triple bypass Kings, King bumpstops front and rear, 17" KMC RG1 powdered in Matte Bronze with black ring with 37" BFG KO2s, front and rear DTF bumpers, front Fiberwerx glass and Mcneil trophy bedsides, K&N 77 Series Intake, Magnaflow, USA SPEC iPod Adapter, Rockford Fosgate 10" sub with custom box and amp. Andres' devil horn emblem, 50" D4 curved LED bar, HID converted hella 4000s. Engine brace, deleted inner wheel wells for max up travel. Cab roll rage built into bedcage.
    hey Eddy, i just switched to 285/70/17. whats my average mpgs now?
  17. Oct 4, 2016 at 8:39 PM
    kjkroll83
    kjkroll83 Well-Known Member
    I knew this is really old but worth a shot. If the difference in tires is 3.4% where did you get 1.034? The difference from my 265/75/16s vs stock is 1.63 but that would give me 27mpg. Which is obviously wrong. Talking to myself lol
  18. Oct 23, 2016 at 8:33 AM
    Tacoma_Tri
    Tacoma_Tri Well-Known Member
    Alan
    2016 Tacoma Limited MGM
    275/65/18 KO2 Front Leveling Kit
    3.4% /100 + 1 = 1.034
  19. Oct 23, 2016 at 8:35 AM
    kjkroll83
  20. Oct 23, 2016 at 8:40 AM
    AdventureKid
    AdventureKid Let's Go Places
    Jake
    Oceanside, CA
    17' DCSB TRD OR 4x4 6MT
    Camper Shell
