265R7516 on a 2016 OR Stock Suspension
Discussion in 'Wheels & Tires' started by Hiker46, Sep 23, 2019.
  1. Sep 23, 2019 at 8:27 PM
    Hiker46
    Hiker46 [OP] Well-Known Member
    Tim
    Colorado
    2023 OR 4X4 Access Cab, Auto Trans,
    OVRLND Camper.
    The spec tire is 265R7016 for my OR but the Toyo Open Country II in C rated only comes in 75 aspect. Will I be able to use the Toyos or will they cause rubbing? Or would I have to go with a narrower tire say 255s?
    Thanks.
  2. Sep 23, 2019 at 8:33 PM
    Jasonstacoma
    Jasonstacoma Well-Known Member
    2019 dcsb Barcelona red
    Stock
    Should fit. I run that size in wildpeaks, no rubbing at all.
  3. Sep 24, 2019 at 6:29 PM
    eurowner
    eurowner Duke Sky
    Scoty
    I run 265-75/16 Toyo Open Country ATIIs on stock 3rd gen alloys and suspension with no problems.
  4. Sep 24, 2019 at 6:37 PM
    Denteen
    Denteen Well-Known Member
    D
    Central valley CA
    2018 TRD Sport 4x4 DCSB
    TRD Pro suspension-2nd Gen Frontrunner bed rack Tacowiede radio knobs! Best mod everrrr!!! DSM mount Wheel swap to OR’s. For now... Gone-2005 DC Icon Stage 2 with Rear Resis;ICON 3 leaf AAL installed! Gone-2001 xcab 4x4 4cyl 5spd. Best truck ever...
    Have you noticed a Significant change to speedo/odo with slightly taller sidewall?
  5. Sep 24, 2019 at 7:07 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Maybe less than 2mph.
  6. Sep 24, 2019 at 7:18 PM
    Denteen
    D
    Central valley CA
    Thank you. I Have a lift and think 75s will fill the gap better. I can deal with a slight change like that
  7. Sep 24, 2019 at 7:23 PM
    Bishop84
    Bishop84 Well-Known Member
    You'll enjoy the ATII's long tread life and they stay quiet. 265/75R16 is the best size for Tacoma. Never rubs and looks good lifted or not lifted.
    Denteen likes this.
  8. Sep 25, 2019 at 10:11 AM
    Hiker46
    Tim
    Colorado
    OVRLND Camper.
    Thanks for the replies!
