265's/285's?
Discussion in 'Wheels & Tires' started by regcabtaco, Dec 11, 2009.
  1. Dec 11, 2009 at 7:22 PM
    regcabtaco
    regcabtaco [OP] Well-Known Member
    idaho
    05 tacoma sr5
    I was wondering im going to be installing a 3" inch lift soon and i was wondering which size tires I should get 265's or 285's? If you would include pictures and why you decide on whichh size.
  2. Dec 11, 2009 at 7:25 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    I got 285s. Just a little rubbin'
  3. Dec 11, 2009 at 7:28 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
  4. Dec 11, 2009 at 7:29 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    If you end up going with 285's, refer to this thread.
    I did some offroading last weekend in Cleghorn, and even with the trimming, my tires sounded like they wanted to rip my fenders off while under flex.
  5. Dec 11, 2009 at 8:17 PM
    regcabtaco
    idaho
    05 tacoma sr5
    With 285's how much rubbing have you guys had? Also what size should I get if i want full flex and no rubbing? Can i get no rubbing with 285's and 3 inch lift?
  6. Dec 11, 2009 at 8:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    With no rubbing, and full flex, your looking at a 265/75/16
  7. Dec 11, 2009 at 8:21 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2...I have a 3" lift myself and I'm running 265/75/16s. I'd like to run 285's but I may have to get a cab mount chop to run them properly...not sure if I wanna do that. Of course i'm just going by what i've heard
  8. Dec 11, 2009 at 8:22 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    you failed to mention if you are using the stock wheels. if you are you will need to get some wheel spacers, and even with them you will still get a little rub(nothing you cant fix with a heat gun). i am personally going with the 265's to get full articulation without rub although i will still probably get the spacers
  9. Dec 11, 2009 at 8:24 PM
    rhodehard09
    tampa, fl
    we have reached the epitome of dead horse beating
  10. Dec 11, 2009 at 8:25 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    In my 1st Gen with 265's i only get a little rub, and I am not lifted yet. You guys should be just fine with the 265's.
  11. Dec 11, 2009 at 8:32 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    when i ran 265/70/17 on stock wheels w/ 1.25" spacers, the only rubbing I had was when I jumped my truck 5 feet in the air, they kissed the fenders. Other than that, I had no issues with rubbing.
    now with the 285/70/17, they dont rub with normal day-2-day driving, but they still rub while flexing. They are still rubbing plastic after trimming (i should trim more) they are also rubbing the cab mounts.
    this with a 3" lift.
  12. Dec 11, 2009 at 8:50 PM
    regcabtaco
    idaho
    05 tacoma sr5
    I think i am going to run 265/75/16's. But now my question is do i need backspacing to have no rubbing with these tires and how much would i need if any?
  13. Dec 11, 2009 at 8:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can run that size just fine on the OEM wheels.
  14. Dec 11, 2009 at 9:23 PM
    rhodehard09
    tampa, fl
    x1 they come stock on the trd off road
  15. Dec 11, 2009 at 9:57 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    IMO I think the tire can make a huge difference...for example, a beefy M/T will look tougher than a highway tire or even a A/T obviously...what I mean is that you don't have to squeeze a big O' tire in the wheel wells to look tough and cool ya know? Function is more important than looks but if you can both than :woot:
  16. Dec 11, 2009 at 10:07 PM
    rhodehard09
    tampa, fl
    x10
  17. Dec 12, 2009 at 5:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No...Stock is a 265/70/16, or a 31" tall tire. A 265/75/16 is a 32" tall tire.
  18. Dec 12, 2009 at 6:05 AM
    goride
    goride Well-Known Member
    Josh
    UTAH
    09 trd sport dbl cab lb
    Tinted windows,Upgraded stereo system,satoshi grill with piaa lights behind,dash light color mod to blue,mag light holder,OME dakar leafs,Toytec ultimate lift,LR uca's, BFG AT's 285/70/17 on Pro Comp 7089s,weather techs, leer shell,CBI sliders and rear bumper w/tire gate,soon DTLT w/ wicked flow catback exhaust
    I went with 285's I had minor rubbing up in the front of the wheel well,I went with the 285's because i think they look better and function the same.Just my 2.
  19. Dec 12, 2009 at 6:59 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    im running the 265s cause i cant bring myself to chop my truck up just for another inch and worse gas milage.
  20. Dec 12, 2009 at 7:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And that extra 1" in tire size only yields about 1/2" in ground clearance. 1/2" grond clearance doesnt mean much. I agree in which I would rather be more able to stuff the tire without rubbing.
