265's on a 2.7L
Discussion in '4 Cylinder' started by 705 Taco, Feb 4, 2011.
  1. Feb 4, 2011 at 6:11 AM
    705 Taco
    705 Taco [OP] Zombie Killer!
    Dean
    Barrie ON / St. Petersburg FL
    2016 TRD OR AC
    --Stock 2016. --------------------------------------------------------------------------------------------- 2011 had 6 inch ProComp lift, Eibach coils on 5100 Bilsteins at zero, 1/4 inch Toytec spacer on drivers side, rear TSB, 1.5 inch Deaver AAL, ProComp blocks and rear shocks, 8000 lb Warn winch on a Trans4mer grill guard, 33 inch BFG AT's, 18x9 XD Monsters, PIAA headlights, PIAA driving lights, Pyro's blue LED gauges, LED strip below tailgate, Armor Lid hard tonno, Hidden Hitch, Dee Zee bed mat, Tint, XM, Garmin GPS, Ultra Gauge
    Is anyone running 265 75 16 Firestone Destination AT's on a 2.7L automatic 4x4? I'm thinking of putting these on my truck and was wondering if they affected performance or gas mileage. I'm staying away from LT tires due to weight so standard load are the ones I'm looking at.
    Thanks.
  2. Feb 4, 2011 at 6:26 AM
    racerxtaco
    racerxtaco Well-Known Member
    Joey
    virginia
    01 xtra-cab 4X4 w/cap
    i run 265 75 dunlop radial rovers. took a very slight hit on mpg's but not too bad, they look real good and havent had any rubbing issues
  3. Feb 4, 2011 at 6:39 AM
    705 Taco
    Dean
    2016 TRD OR AC
    Did you get the LT or standard load?
  4. Feb 4, 2011 at 7:06 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Just another suggestion from someone who's done a lot of research on it. I have the 2.7 as well. I ended up going with the 265/75r16 Hankook Dynapro ATM's in P rated. They were only 6 lbs per tire heavier than the stock Dunlops. When you consider the fact that my stock Dunlops were 245/75r16's that's really impressive. I'm seeing a little drop in MPG's but I also switched right before the winter so I'm sure a lot of my drop is due to the cold weather and winter gas.
  5. Feb 4, 2011 at 7:44 AM
    Quick_1911
    Quick_1911 Well-Known Member
    Brad
    Georgia
    08 Prerunner
    I'm running 265/70/17 Dynapro ATM's on my 2.7 5 speed and I didn't really feel any power loss, being a manual transmission really helps though.
  6. Feb 5, 2011 at 1:57 PM
    705 Taco
    Dean
    2016 TRD OR AC
    Thanks for the info guys. I'm gonna stick with a P rated tire because as you said they are much lighter than LT tires. I would rather have a slightly larger lightweight tire than a heavy duty LT tire since I mostly drive on road.
  7. Feb 5, 2011 at 2:06 PM
    zabstaCOma
    zabstaCOma Well-Known Member
    Nate
    Colorado
    2012 toyota tacoma TRD off road
    -debagged -shorty black antenna 14'
    I had 265 75 16 Firestone Destination AT's on my truck and i did find that it robbed me of performance and HP. I had them on for a year and then gave them to by brother who had a TRD, and went back to the 245 75 16 Firestone Destination AT's, and the truck runs a hell of a lot better. I live in Colorado up past 7000 feet and I will NOT run anything but 245 75 16 on my truck since i need all the HP that i can get from the little truck.
    My option is go with the 245 75 16 Firestone Destination AT's, they are a good tire.
