265x70x17 vs 285x75x16
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mountainwolf, Jun 15, 2017.
  1. Jun 20, 2017 at 11:53 AM
    #41
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    From my understanding, but i'm not a tire expert as we have seen, if your rim is a 17 and the tire can fit on a 17 then it's good to go. Now, once the side wall gets larger and larger, you're going to get a balloon looking affect. As far as performance goes, I have no idea what can result.
  2. Jun 20, 2017 at 11:59 AM
    #42
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Terrible idea. There is not enough back spacing and you will for sure rub the UCA. You will also rub the cab mount, pinch weld, and plastic. Go ahead and try it, but don't say I didn't warn you.
    Now that I'm unsure of.
    saundern[QUOTED] likes this.
  3. Jun 20, 2017 at 2:50 PM
    #43
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    i know my cousin has KO2s on his FJ stock height in that size no rub, but he doesn't really wheel with it. Not sure that helps.
    I've heard in numerous threads on here it doesn't rub under normal driving but under flex it does.
    You might be able to get away with it. Not sure what the offset is for the OEM wheels so dunno.
  4. Jun 20, 2017 at 3:31 PM
    #44
    yarberrymt
    yarberrymt Well-Known Member
    Remember...99% of 285/75/16 tires are load E rated....which translates to much heavier tires, more rolling mass to start and stop which affects acceleration, braking, mpg etc.
    The advantage of 17" wheel is you can find similar sized (diameter) tires that are C rated (*I think), which IMO, is much better suited to a Tacoma - and even moreso the 3rd gen 3.5L motor.
    That said - I love the proportion, looks and rubber to wheel ratio of a 285/75/16, which is what I'm going with soon.
  5. Jun 20, 2017 at 3:33 PM
    #45
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You are right! The nitto ridge grappler is one example of a C load 285
