26k miles - on 2010 - change the plugs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrcheap, Jul 7, 2020.
  1. Jul 7, 2020 at 2:10 PM
    mrcheap
    mrcheap [OP] Well-Known Member
    ok i tricked you, it's a 2010 honda cr-v.
    just curious on what the consensus is?
    it's my dad's car - he barely drives it.
    should i go ahead and change the plugs or it's all about mileage and not years?
    thanks!
  2. Jul 7, 2020 at 2:29 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I tried to look it up.
    Apparently it has a maintenance minder system
    My under standing is, that it will tell you when they need replaced.
    I believe a #4 will come on to indicate the plugs need changed.
    I could be wrong, seems like it would be easier to just have it printed on a schedule.
    Then again, some cars don’t even have an engine oil dip stick. You get a light to indicate low oil.
    I’m not too sure on all this new “technology”
    Call the dealer or pull a plug and look.
    That’s all the help I can give you.
  3. Jul 7, 2020 at 2:55 PM
    fatrip
    fatrip Well-Known Member
    Vince
    Upstate NY
    07 Taco 4D Short
    Bilstein 5100's , 885.
    Everything I saw was 10yr-100k but at 26k I wouldn’t change. If you pull now they will look brand new.
  4. Jul 7, 2020 at 2:56 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    I wouldn't change them. Especially if everything is running fine.
    TnShooter likes this.
  5. Jul 7, 2020 at 3:08 PM
    mrcheap
    thanks - sorry for the trick - but it's really general car advice and my taco buddies are always quick to respond
  6. Jul 7, 2020 at 3:20 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Leave em in.
  7. Jul 7, 2020 at 3:23 PM
    Masshole_And_His_Taco
    Masshole_And_His_Taco RIP Rick
    Northish South Shore MA
    Two-seater Curb-eater
    Little bit of stuff.
    Honda's recommended service interval (I work for Honda) is every 105k and to be coupled with a valve adjustment at that interval. So long as you have no other underlying issues or concerns that could be related, let them be.
