275/70/17 (32") tires - will they fit?
Discussion in 'Wheels & Tires' started by STEVECBR929RR, Jul 21, 2010.
  1. Jul 21, 2010 at 11:12 AM
    STEVECBR929RR
    STEVECBR929RR [OP] STEVECBR929RR
    STEVE
    CONNECTICUT
    06 TACOMA DBL CAB SR5 TRD
    black nerf bars, AVS in channel rain guards
    ok guys,
    Anyone know if I can fit 275/70/17 (32") tires with the bilstein 5100's and nothing else without rubbing or trimming?
    thanks!!
  2. Jul 21, 2010 at 11:17 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Yep, they should fit in general on the stock rims. Exactly what brand of tire are you talking about though
  3. Jul 21, 2010 at 11:20 AM
    STEVECBR929RR
    STEVE
    CONNECTICUT
    Thanks!
    I sure hope so! Everyone says you will need to trim with 285/70/17 or else they will rub. And if you ask me there is no point in installin the billies if I am only going to run 265/70/17's as those will fit with the stock suspension. I figure 275/70/17 is a good middle ground...
    Any other thoughts?
  4. Jul 21, 2010 at 11:31 AM
    sanga700
    sanga700 Well-Known Member
    San Diego, CA
    09 Red Tacoma SR5 4x4 V6 6sp
    TRD intake Airbox,4 corners 5100 front set @ 2.5".Rear TSB,1.5" Toytec AAL,skid plate.running board, EGR in channel sun visors,Valetine one radar detector, 17x8.5 Black MB Wheels. 265/70/17 Handkook Dynapro ATM
    I ran 275/65/17 TRD stock wheel. I then have a local shop installed 275/70/17 to see if they fit but, they WON't fit because it rubbed so bad on stock UCA . Im running all 4 corners of 5100 @ 1.75 "
  5. Jul 21, 2010 at 11:32 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Do a search for your exact type of tire in that size..plenty of guys running those
  6. Jul 21, 2010 at 11:35 AM
    STEVECBR929RR
    STEVE
    CONNECTICUT
    I wanted to buy Goodyear Duratracs but they dont make them in 275/70/17 so probably BF Goodrich...
  7. Jul 21, 2010 at 11:37 AM
    STEVECBR929RR
    STEVE
    CONNECTICUT
    Sanga, maybe they would have fit at 2.75 instead of 1.75? no?
  8. Jul 21, 2010 at 12:07 PM
    sanga700
    San Diego, CA
    with 275/70/17 I think you have to run with aftermarket wheels with big backspacing or wheel spacers with stock wheels at 1.75"
  9. Jul 21, 2010 at 12:28 PM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
  10. Jul 21, 2010 at 12:58 PM
    STEVECBR929RR
    STEVE
    CONNECTICUT
    yeah believe it or not I saw that link - still sounds like some are saying it will rub the UCAs and some are saying it wont...
  11. Jul 21, 2010 at 1:30 PM
    sanga700
    San Diego, CA
    OK . Here is my advise why don't you go to your local tire shop talk to them and have them mount 2 front tires . That's the best way you could decide yourself .
  12. Jul 22, 2010 at 10:44 AM
    raycie
    raycie Well-Known Member
    Oahu, HI
    16 T4R Trail
    In need of $$$
    With 265/70/17 on stock suspension I was fine.. With 5100's set at 1.75 I had to trim. Yes this is 265's,, so with a larger tire you would also need to trim.
  13. Jul 22, 2010 at 12:51 PM
    sanga700
    San Diego, CA
    Every truck had a bit diffirent . Im currently running 265/70.17 handkook tires with all 4 corners of 5100@1.75" without any rub at all . Also I ran 265/75.16 or 275/65/17 without any rub at all .
  14. Jul 22, 2010 at 2:23 PM
    raycie
    Oahu, HI
    16 T4R Trail
    In need of $$$
    wow..differences.. You're telling me.. My truck can't have billies @ 1.75 in the rear.. And you have 1.75 at all 4 corners??? Wow.. J/K...
    my rub was not driving, was when wheel was turned, and I went over speed bump or into driveway...
  15. Jul 23, 2010 at 9:57 PM
    1BADTOY
    1BADTOY Member
    Chattanooga, TN
    07 Tacoma 4X4 TRD Sport D-Cab
    Biltein's 5100 @1.75, TSB suspension
    Im running michelin 265/70/17 on mine with 5100s front set at 1.75 and tsb leaf in rear. i did get very minor rub on arms, which stopped in a couple months, and certainly never had to cut anything.
    now im wanting a slightly larger tire.. maybe a 275/70/17, but will probably set the front at 2.5 and add another leaf to rear.. but dont know yet if this is possible on stock rims and if it is whether or not it will cause any problems.. will prob just get new rims..
    ...still researching
