275/70/17 on stock Sport Wheels ?
Discussion in 'Wheels & Tires' started by OZ-T, Dec 6, 2011.
  1. Dec 6, 2011 at 12:27 PM
    OZ-T
    OZ-T [OP] You are going backwards
    Peter North
    British Columbia
    So , I've spent lots of time reading all the relative threads , but there doesn't seem to be a definitive answer .
    Can you run 275/70/17 on Sport wheels and clear the fender , flaps and UCA's ?
    I have 2 1/2" of front lift and LR UCA's .
    Thanks in advance .
    *******SPOILER ALERT******* : For those too lazy to read to the end , the answer is yes .
    Dick4x4 and Kolter45 like this.
  2. Dec 6, 2011 at 12:32 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    :popcorn:
    Worst case you could do some measuring at full lock and flexed based on the size you have now. They don't seem much larger than the 265/70's (1/2" wider, 1/2" taller).
  3. Dec 6, 2011 at 1:31 PM
    BigBiscuit
    BigBiscuit Well-Known Member
    Mass.
    2010 TRD Sport DCSB MGM
    I asked a while ago and also never got a definitive answer either. Based on some measurements I made, I think you're okay. The only question I had that went unanswered was related to clearing the UCA's. I still don't know. I'm thinking you might need wheel spacers for insurance.
  4. Dec 6, 2011 at 1:34 PM
    OZ-T
    Peter North
    British Columbia
    I've read a few guys contact the UCA at full lock .
    Wheel spacers would probably make the tire contact the flaps which I would like to keep .
  5. Dec 6, 2011 at 3:25 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    IIRC member Teamfast had those and he said he had slight rub on the uca. I'm really thinking about going that direction when I get new tires in a few weeks
  6. Dec 6, 2011 at 6:45 PM
    OZ-T
    Peter North
    British Columbia
    He said he had a slight rub on the UCA at full lock
  7. Dec 6, 2011 at 11:01 PM
    OZ-T
    Peter North
    British Columbia
    bump
  8. Dec 6, 2011 at 11:37 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    IMHO, get new rims with your tires :p... but serisously I think you'll be fine. Hard to tell though, it seems many of our "same" trucks have very different results from certain modifications.
    OFF topic a bit; the 275/70/17's... what tire are you going with? When I bought my last set of tires that size was virtually impossible to find :confused:
  9. Dec 7, 2011 at 12:04 AM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    This really is tough to answer without real world testing, though it should work. You're only gaining 1/4" in height and 1/5" in width, which isn't much with 2.5" of lift. How much room do you have between the tire and your UCA now? Do you have any rubbing with your current tires?
    Theoretically it "should" work, but you never know just how much half an inch will do. That's an uncommon size btw, what tires are you looking at getting?
  10. Dec 7, 2011 at 12:36 AM
    Lateralus
    Lateralus Senior Member
    Las Vegas
    07 4x4 Off Road
    Too many to list..
  11. Dec 7, 2011 at 12:48 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    A friend of mine runs that size on an aftermarket wheel, but the same measurements as stock IIRC.
    He didn't have to trim anything or had problems with UCA contact.
    but then again, different trucks seem to have different results
  12. Dec 7, 2011 at 7:27 AM
    OZ-T
    Peter North
    British Columbia
    The Hankook ATm's are available in an LT275/70/17 Load Range C now .
  13. Dec 7, 2011 at 7:28 AM
    OZ-T
    Peter North
    British Columbia
    Hankook ATm
  14. Dec 7, 2011 at 10:29 AM
    OZ-T
    Peter North
    British Columbia
    Bump
  15. Dec 7, 2011 at 10:34 AM
    OZ-T
    Peter North
    British Columbia
  16. Dec 7, 2011 at 10:53 AM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    That must be a brand new size.
    I just rec'd delivery of the same tire in P265/70/17 and they look very, very good. The open tread shouldn't carry stones and the continuous center band should keep them quiet.
    I wouldn't be afraid to put 275's on my stock FJ wheels, just wouldn't want the weight on the 2.7
    The P265's are only 38#
    I've run tires for hundreds of thousands of miles with a slight rub at full lock on my Jeep with no problem. Just don't want to rub on anything sharp. The 275's might be tight.
  17. Dec 7, 2011 at 11:16 AM
    OZ-T
    Peter North
    British Columbia
    New size as if spring 2011
    I run 265/70/17 Hankook Dynapro MT's now , and these should only be 10mm wider , and only half of that , 5mm or 1/4" , would be toward the UCA . By eyeballing it , it looks like I should have room even at full lock .
  18. Dec 7, 2011 at 11:22 AM
    Pugga
    Massachusetts
    Only one sure way to find out!
  19. Dec 7, 2011 at 11:25 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    where is kpt lol
  20. Dec 7, 2011 at 3:07 PM
    98regstick
    98regstick Well-Known Member
    Maryland
    '11 DCSB SR5
    OME 90021 with 885s and top plate spacer, 2" AAL, OME rear shocks, Camburg Uniball UCAs, OME CB Drop, 285/75/16 BFG AT's on Level 8 Guardian wheels
    bingo
