275 or 285?
Discussion in 'Wheels & Tires' started by JP22, Sep 16, 2012.
  1. Sep 16, 2012 at 7:52 PM
    JP22
    JP22 [OP] Active Member
    Alabama
    09 DCSB 4X4
    I have the lift (ome 885x w/dakar rear) and wheels (17x9 4.5 bs) now need to buy tires. I am looking for either 275/70 or 285/70. trying to decide which one will need less trimming. I live in a small town so there is no "test fit" option. Order and install, I just don't want to wish I had gotten the other. I'm sure there are some with the same setup that can give advice.
  2. Sep 17, 2012 at 12:35 AM
    ae111black
    ae111black Well-Known Member
    Kimo
    Pahoa Hawaii
    10 TRD off road doublecab 4x4 silver
    Da Kine 255's
    I have 285/75/16's on my truck with billies@ 2.5" on my stock OR rims and They fit. those should be the same size as the 285/70's but your rims are gonna make the tire hit the Cab mount some @ compresson
  3. Sep 17, 2012 at 12:42 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    285 is more of A common size... 275 is an odd size tire... You'd have more to choose from with 285s than A 275.
  4. Sep 17, 2012 at 2:50 AM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Well, the 275 would definitely need less trimming. 285 without trimming is generally not considered possible. 275 is about as high as you can go without trimming if you have a lift. I have the OME/Dakar lift also with 886 on TRD Sport wheels. My tires are 275s and I have the slightest bit of rubbing on my driver side fender at right lock.
  5. Sep 17, 2012 at 4:40 AM
    JP22
    Alabama
    09 DCSB 4X4
    I know that I will have to trim some plastic no matter which tire I use. But I didn't want to have to buy 2 sets of tires. I can get Cooper discoverer at3 in both sizes. They look good and are made about 70 miles from where I live so I could kind of help local industry. I would rather have the st maxx, but they are a 10 ply tire and will probably ride rough but they only come in 285 for 17 inch.
  6. Sep 17, 2012 at 7:06 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I run 275/70/17 , zero trimming , I even had the front flaps on , but I am on stock Sport Alloys
  7. Sep 17, 2012 at 6:10 PM
    JP22
    Alabama
    09 DCSB 4X4
    Sport alloys are 17" also? so I shouldn't have much trimming involved with 275 on this truck either.
  8. Sep 17, 2012 at 6:12 PM
    OZ-T
    Peter North
    British Columbia
    The backspacing is different though
  9. Sep 18, 2012 at 9:26 AM
    JP22
    Alabama
    09 DCSB 4X4
    Thanks for the help! I really appreciate the insight.
  10. Sep 18, 2012 at 9:50 AM
    OZ-T
    Peter North
    British Columbia
    What I'm saying is that you are more likely to rub the fender with your wheel backspacing than mine
  11. Sep 18, 2012 at 8:10 PM
    JP22
    Alabama
    09 DCSB 4X4
    I installed the lift today. I know it will settle some, but right now it is 3 1/4" measured from center of the hub to the flare. I took a stock 17" wheel with a 265/70 and put it on my truck and there was PLENTY of clearance. I know the width is less and backspacing is different, but the way I measured with the wheels turned at all different angles a 275/70 will fit with no rubbing. So I ordered them and will put them on thursday. Thanks for all the advice I really appreciate the help.
  12. Sep 19, 2012 at 9:53 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    did you compress the suspension (remove CO's) to the bump stops while turning ?
