275 tire 18" rim setup... With 5100?????
Discussion in 'Wheels & Tires' started by Tacoma343, Nov 9, 2012.
  1. Nov 9, 2012 at 3:32 PM
    Tacoma343
    Tacoma343 [OP] Well-Known Member
    Jesse
    La Quinta, Ca
    2016 Taco White TRD Sport DCLB W
    Soon! 1 month!
    Anyone besides KPT running this setup with a 18 inch rim and 275/70... Going with billies set at 1.75 and deciding between Nitto Terra and the brand new Toyo Open Country AT II. Wanna run as close to a 33" tire without going with 285.
    Pictures?? Thanks Pardsys!
  2. Nov 9, 2012 at 5:15 PM
    Tacoma343
    Jesse
    La Quinta, Ca
    Soon! 1 month!
    I've searched but.... Anybody?
  3. Nov 10, 2012 at 6:50 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    lol I got so excited until I saw the "besides KPT" :laugh:
  4. Nov 10, 2012 at 8:06 AM
    Tacoma343
    Jesse
    La Quinta, Ca
    Soon! 1 month!
    I've paid attention to all your info KPT... I just can't decide what route I wanna go as far as tires. I really like Azonicbruce's setup with that new Toyo OC ATII with method double standard 16", his tire is 31.6 in diameter. I'm going billy 5100 at 1.75 I think so I wanna fit the closest to a 33 as possible. That is why I like this 275/18 option.
    Are your Terra's the LT tire or P Metric? The LT 275/70R18 runs at 33.27 the p metric is @ 32.05. How do like the setup with the Terra's? And did you end up trimming after the switch from the Dynopros?
  5. Nov 10, 2012 at 8:23 AM
    KPT
    09 Prerunner
    I'm running the P metrics. I had to cut off the piece of the fender well liner than hangs down below the bumper level.
  6. Nov 10, 2012 at 11:47 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    You won't be able to fit a 275/70/18 without A LOT of trimming at 1.75". That's almost a 34" tire. My buddy ran them with 2" of lift and we had to trim a ton of plastic out of the wheel wells, and they still rubbed cab mount.
    Edit, I just noticed you said P. You'll still have a lot of trimming to do in a 275/70. I would look at 275/65's.
  7. Nov 10, 2012 at 11:50 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    275/70/18 is 33 1/4
  8. Nov 11, 2012 at 8:18 AM
    Tacoma343
    Jesse
    La Quinta, Ca
    Soon! 1 month!
    Ok so 275/65 should be ok?
  9. Nov 11, 2012 at 8:33 AM
    KPT
    09 Prerunner
    Ahh, i misread the first post. I have 275/65s not 275/70s
  10. Nov 11, 2012 at 8:54 AM
    Blueanimal
    Blueanimal Well-Known Member
    New Orleans area, La
    06 Prerunner Sport
    K&N 77 series intake, Throttle boby spacer, Bilstien 5100, Firestone airbags, Brush Gaurd, Gooseneck hitch, Whelen lights and siren
    275/65/18 on 5100's w/885. I did have just the 5100's set at 2.5 originally. Had a chance to get 885's and went with it. Had to trim the part that stuck out below the fender and a little in a couple other spots, but I have zero rubbing now even at full stuff w/ full lock.
  11. Nov 11, 2012 at 8:59 AM
    Tacoma343
    Jesse
    La Quinta, Ca
    Soon! 1 month!
    KPT what's the diameter of those Terra's?
  12. Nov 11, 2012 at 9:00 AM
    Tacoma343
    Jesse
    La Quinta, Ca
    Soon! 1 month!
    Never mind I already posted diameter of pmetric above
