27F CCA rating for toyota canada/johnson controls
Discussion in '2nd Gen. Tacomas (2005-2015)' started by landphil, Oct 4, 2012.
  1. Oct 4, 2012 at 10:54 PM
    landphil
    landphil [OP] Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    The tag went missing off my OE toyota battery, and I cant remember the CCA rating. Its the Toyota Canada / Johnson controls 27F. Trying to load test it accurately, if anyone can help I would be very appreciative.
    On a side note, I will eventually be installing a group 31 top stud commercial battery, found out tonight it will fit with some relativly minor modifications to the hold downs and cables. The results of the load test will determine the urgency. The benefits are: a lot more battery, for a lot less $$, and dual purpose ( cross between a starting battery and a deep cycle ) are available.
  2. Oct 5, 2012 at 5:55 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    N. E. Buddy?
  3. Oct 5, 2012 at 6:53 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    give me a sec..check my 06
  4. Oct 5, 2012 at 6:56 PM
    aficianado
    back to bone stock.
  5. Oct 5, 2012 at 7:02 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Thanks mucho! That means my current battery fails the load test, even though still starting fine. Still tests at 575 CCA though, could probably get through the winter, might try if I didn't plan to go hunting in remote areas. Group 31, here I come. Time to build a new hold down bolt and one longer cable to the power distribution box.
    Its about 1" taller, and 1" longer, but fits in the tray fine. I got this one free, but we pay 90ish for quality ones through my work. It will pay off when I get around to installing my winch too.
  6. Oct 5, 2012 at 7:17 PM
    aficianado
    back to bone stock.
    surprised your battery is still kicking with your brutal winters..
    mine passed load testing about a year ago. i am keeping an eye on it..it is approaching 7 years old..not bad for a stocker. but i live in a country club for batteries, weather-wise.
    your welcome!!
  7. Oct 5, 2012 at 7:18 PM
    aficianado
    back to bone stock.
    can you load test a battery with a multimeter?
    or do you have a load tester?
  8. Oct 5, 2012 at 7:29 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    I have a capacitance battery tester, googe OTC 3183 for more info. No, a multimeter alone will not suffice.
    I keep my battery terminals clean and electrolyte topped of with distilled water as needed, and never run my batteries down, which all helps with life. Maybe a good dose of luck too? My previous vehicle was a '96 civic, I replaced the OE delco at 11 years old, still started OK, but it too failed load testing. I won't be pushing my limits with this one when I have that almost new G31 sitting in my shop waiting for a home.
