280k and no maintenance. What to do?
Discussion in '1st Gen. Tacomas (1995-2004)' started by maximilian55, Dec 8, 2013.
  1. Dec 8, 2013 at 9:07 PM
    maximilian55
    maximilian55 [OP] Well-Known Member
    max
    washington
    95.5 Tacoma 3.4l
    So my Tacoma just passed 280k, and I just found out that it is very possible that the fluids in the transmission/differentials, have never been changed. I just bought oil for it, Hypoid something oil for the diff? and gear oil for the manual transmission?
    however I saw a few people saying that since it has never been done, that its best to just leave it as it is, otherwise it might damage it even further. I don't have any issues with the truck, but I just want to have that peace of mind and keep everything running for a long time.
    So should I go ahead with the fluid changes? or is it best to just keep it how it is?
  2. Dec 8, 2013 at 9:12 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I'd change them... the problems with tranny fluid changes at high mileage are more with the automatic's.
  3. Dec 8, 2013 at 9:15 PM
    maximilian55
    max
    washington
    95.5 Tacoma 3.4l
    Ok thats what i was thinking/hoping. And does those types of oil sound right? Ive never done this before.
  4. Dec 8, 2013 at 9:17 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Change it. Use the correct weight stated in the manual. Brand doesn't matter.
  5. Dec 8, 2013 at 9:25 PM
    jdkilroy
    jdkilroy Well-Known Member
    Jon
    Southern NH
    '02 4x4 SR5 Access Cab
    There is absolutely no argument for continuing to ignore basic maintainence.
    There are concerns in automatic transmissions about doing a flush rather than the drain and fill when dealing with high mileage vehicles because there is the risk of stirring up deposits in the tranny that could cause problems.
    This is not the case with manual transmissions and you should change out the fluids per maintainence guidelines
  6. Dec 9, 2013 at 1:22 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    Change them, for sure!
    I use Redline MT90 (75w 90) for my Transmission and Transfer
    And Regular Redline 75w 90 in both diffs; I have open diffs, though; if you've got an LSD or an E-locker, I think you will need something different (same weight, special blend)
  7. Dec 9, 2013 at 8:07 AM
    Moco
    Moco Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    How long have you had it (not necessarily in chronological terms, but mileage terms)?
    Definitely start with fluid changes for the tranny, transfer case, rear, and front differentials.
    Make sure you are getting a good motor oil in there on a regular basis (I recommend Mobil 1 5w-20 high mileage and an OEM Toyota filter).
    You might want to consider bleeding your brakes and clutch as well.
    Everything after that is regular maintenance of wear parts (brakes, bushings, ball joints, etc. etc.)
    Good luck. If the motor/tranny have made it to 280K miles, someone has been doing some maintenance, so it cant be too horrid.
  8. Dec 9, 2013 at 8:13 AM
    Madjik_Man
    Colorado Front Range
    Definitely change them.
    And my personal advice for the manual tranny gear oil: Redline MT-90
    I changed mine for the first time in probably 100,000 miles and used Royal Purple. They should change the name to Royally Sucks Balls.
    After a few thousand miles I changed it to Redline MT-90 and it is fantastic.
    In 30 degree weather, I wouldn't be able to put it into gear, or reverse, in the morning using Royal Purple. And even after warmed up, the shifting was very notchy and awful feeling.
    This past week it's been -15 degrees in the morning and no more than a high of 5 or so. Redline MT-90 still feels like butter, even cold.
