285/60R18 on XD Monsters - PICS!!!
Discussion in 'Wheels & Tires' started by se7en, Feb 6, 2010.
  1. Feb 6, 2010 at 5:22 PM
    mikestadoodle
    mikestadoodle New Member
    Michael
    Orem, Utah
    04 tacoma 4x4 trd offroad
    3" toytec lift, 285/65/18 Nitto Trail Grapplers with 18" XD Monsters. Flowmaster 50 series, deck plate mod, putting in 2 8" kickers behind back bench.
    I have 285/65/18 Trail Grapplers with monsters and I ditched my mudflaps too. It looks a lot better. All they do is get in the way especially when your tires stick out that far.
  2. Feb 6, 2010 at 5:28 PM
    se7en
    se7en [OP] Go Vols!
    East TN
    25 TRD PRO - Ice Cap
    Persactly! I'm on the other side of most in thinking that they actually look better on than off...and what you said. Protection. I think the 1.5" lift will get me enough clearance that in 98% of my daily driving, it'll not rub.
  3. Feb 6, 2010 at 5:33 PM
    86ceeten
    86ceeten Well-Known Member
    Brian
    NW Florida
    08 TRD Off Road PreRunner
    Limo tint, 18x10 Diamo Karat, Toyo 285-60's, Rear TSB, 5100's all around, front at 2.5", Debadged, Sound System (evolving)
    Looks great! A little lift will set it off. I would try to keep the flaps also. After 33,000 miles on my 08, I don't have any rock chips on the rockers.
  4. Feb 6, 2010 at 7:45 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Looks awesome! SOO much better. This was w/ a -12 offset right?
  5. Feb 6, 2010 at 8:57 PM
    Tool
    Tool Who Inspires You?
    Riverside, CA
    07 PreRunner TRD Sport
    TRD SuperCharger 6in ProComp Lift, DTLT Headers, JBA Exhaust, Pioneer Appradio 4, Coverking seat covers, 2 10in Rockford Fosgate subs, Rockford Fosgate Amp, N-fabs, 6000k HID LED Taillights
    Looks good
  6. Feb 7, 2010 at 4:44 AM
    se7en
    se7en [OP] Go Vols!
    East TN
    Yup. 4.5" backspace and -12mm offset. I actually didn't want it to stick out this far. I was shooting for the look of Chris4x4's, where everything is more under the fenders. He said he didn't remember the offset but it must have been the 5.71 backspace and +18mm offset. Though, I'm not sure how his doesn't rub more on the internals...:confused:
  7. Feb 8, 2010 at 3:42 AM
    se7en
    se7en [OP] Go Vols!
    East TN
    Problem solved.
    No flaps. No rub. No problem. :D
  8. Feb 8, 2010 at 8:00 AM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    Nice, so you still wanting to lift? I think it looks pretty bad ass without a lift.
  9. Feb 8, 2010 at 8:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    My rims are a 4.5" back space....Not sure on the off set, as my Wife bought them for me. :eek:
  10. Feb 8, 2010 at 8:12 AM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Is it stamped on the inside of the rims?
  11. Feb 8, 2010 at 8:12 AM
    i2andom81
    i2andom81 Well-Known Member
    Denver
    08 black prerunner
    Fox coilovers and resi rears, 20% tint, wet okole trd seat covers, LCE engineering headers, custom magnaflow exhaust, afe cai, satoshi grill, URD supercharger, retrofitted headlights, weather tech mats, standard duty leafs, allpro front bumper and uca
    i have 285s with some rockstars that are the same size and i had to cut into the bumper to remove all rubbing. i also have a 3" lift. im confused how just removing the mudflaps will get rid of the rubbing?
  12. Feb 8, 2010 at 8:14 AM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    I think its because he isnt moving. I think he will still have rubbing when he is driving, hitting bumps and stuff
  13. Feb 8, 2010 at 8:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I looked for it and didnt se it. It IS stamped "18x9"
  14. Feb 8, 2010 at 8:20 AM
    i2andom81
    Denver
    08 black prerunner
    ok ya. i mean when he needs to crank his steering wheel, his truck is going to hear it for sure rubbing on the plastic. se7en if they dont rub while driving, then thats a miracle. if they do rub, just cut into the bumper to give your tires more room to travel. or just get an offroad bumper with more space for the front tires.
  15. Feb 8, 2010 at 8:23 AM
    #35
    91Toyotabogger
    91Toyotabogger "Loud Tires Can Save Lives"
    North Carolina
    91 4wd 5sp manual Pickup Standard cab white
    Mud Tires, CD player, CB radio with PA speaker, De-badged, window decals, Flow Master 40 series
    that truck is bad ass i like it both ways, those tires look tough:D
  16. Feb 8, 2010 at 8:24 AM
    #36
    se7en
    se7en [OP] Go Vols!
    East TN
    I lost a half inch of gap between the bottom of the fender and top of the new tires due to the size. What's a better way to fix it than adding 3 times more than I lost...?:D Seriously, I'm still leaning towards a small 1.5" spacer lift with Bilsteins and blocks in the rear. For no other reason than "just in case" the opportunity arises for some light-duty wheelin'.
    If that's the case, why doesn't yours stick out as far from under the fender as mine? I mean, essentially, we have the exact same setup (minus lift) and I stick out 2.25". The only way that could be is if you were in toward the frame an inch or so. Juding by the catalog options in your rim (Helo Maxx 6), the only other option is the 5.71" bs or the 5.56" bs with +18 and +15mm offsets respectively.
  17. Feb 8, 2010 at 8:26 AM
    #37
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmm.....If it was the 5.71 or 5.56 BS, It would have rubbed the stock UCA's. It didnt. :confused:
  18. Feb 8, 2010 at 8:28 AM
    #38
    se7en
    se7en [OP] Go Vols!
    East TN
    No, no, no. I have put over 100 miles on her since removing the flaps yesterday and I don't rub except when in reverse and at full lock on the steering wheel. Swear.
  19. Feb 8, 2010 at 8:29 AM
    #39
    se7en
    se7en [OP] Go Vols!
    East TN
    With mine, I've got about 1.25" of clearance between the side of the tire and the UCA as it stands.
  20. Feb 8, 2010 at 8:31 AM
    #40
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmm.....Interesting. I had about 1/8" with the stock UCA's. Im wondering how I can go about finding the exact size of the wheel??
