285-65-18's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by redtacoma, Sep 8, 2010.
  1. Sep 8, 2010 at 7:58 PM
    redtacoma
    redtacoma [OP] Member
    san diego
    06 tacoma crew cab
    question i just bought a 06 tacoma dc 4x2 the guy did a lift on it 5100's all the way around. the front is set at 0 with a 2 inch spacer very little to no rubbing i would like to remove the 2 inch spacer and run it at 1.75 setting do you guys think it is possible if i have to trim the fender liner that is not a problem any ideas will help.. here is the only pic i have so far
    Thanks
    Tacoma world
  2. Sep 8, 2010 at 8:02 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Think you need at least 3" lift to fit those tires. depending on type of tire and BS of wheel.
    Post these questions in appropriate sections.
  3. Sep 8, 2010 at 8:02 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    that spacer kind of defeats the purpose of the billies. Do that and then get an alignment of course.
  4. Sep 8, 2010 at 8:08 PM
    pm321
    pm321 Well-Known Member
    I ran 285/65/18 with just a little 1 1/4 inch spacer us front with no rubbing issues at all?
  5. Sep 8, 2010 at 8:11 PM
    S.B.
    Sean
    Lift is not needed. Lift just determines when the tire is going to rub on up travel.
