285-65-R16 on stock suspension
Discussion in 'Wheels & Tires' started by AWorthyOpponent, May 8, 2012.
  1. May 8, 2012 at 8:03 PM
    AWorthyOpponent
    AWorthyOpponent [OP] Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    Okay, so I know that 265-75-R16 is the largest tire you can't run on a stock suspension, without rubbing. That would change the tire from a stock diameter of 30.61 inches to a new diameter of 31.65 inches, a 1.04 inch difference. I understand the concept that the larger diameter tire would be the largest you could run without a lift. I also know, there are a lot of people on these forms that want to run 285 wide tires. The difference in width of the the stock tires and the 285 tires is only 20 mm. That means adding an additional 10 mm on each side of the tire. What if you kept the tire at the same diameter, just made the tire wider? Could you run 285–65-R16 tires, with a stock suspension? The tire would go from a 30.61 inch diameter tire to a 30.59 inch diameter. Making it .02 inches smaller, and only 20 mm wider. Would the 10 mm on each side of the tire tread rub?
    Even at full lock when I had my stock rims, it didn't seem like the was 10 mm away from any of the components on either side. I now have aftermarket rims, and I think they would look better with the wider tire. It is not necessarily something I am going to do in the near future, but I am more curious what would be involved.
  2. May 8, 2012 at 8:05 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Who makes a 285/65/16?
  3. May 8, 2012 at 8:11 PM
    KPT
    09 Prerunner
    Well then I think i know a guy who would be interested.
  4. May 8, 2012 at 8:14 PM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    I don't know, but this is how I came up with that size...I assumed that it could be found.
    http://bit.ly/JezisJ
    (not intended to be a smartass link...it's what I did.)
  5. May 8, 2012 at 8:17 PM
    KPT
    09 Prerunner
    That's also what I did. That how I know that no one makes an AT tire in that size.
  6. May 8, 2012 at 8:20 PM
    KPT
    09 Prerunner
    Your overall logic is good though. Several folks on here run 285/60/18 on stock suspension
  7. May 8, 2012 at 8:22 PM
    jsmarine
    jsmarine Well-Known Member
    Jeff
    Dallas, TX
    2005 Tacoma SR5 Crew Cab 4x4
    ARB front & rear lockers ARB bull bar Warn XP9000 winch IPF lights
    That is not a size anyone makes as others have said, but in addition, most tire fitment issues come from width, not height. Its easier to fit a taller skinner tire, than a short fatter tire.
  8. May 8, 2012 at 8:29 PM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    That's more what I was getting at. I was curious if it was the width or the height that limited the tire size on our trucks. Everything I've read just says that 265-75-R16 is the largest, with no explanation, just derp comments and BS making fun of someone for asking questions...
    +1 for answering, even with the hint of sarcasm...
  9. May 9, 2012 at 4:48 PM
    KPT
    09 Prerunner
    That's what I'm here for, especially the sarcasm. :thumbsup:
  10. Jul 5, 2012 at 10:46 AM
    Retiredlinetrash
    Retiredlinetrash Member
    Plug
    Ca
    Prerunner TRD Off-Road
    2.25" front end lift & 1" lift in rear.
    Im looking for the same thing.. I have a 2.25" lift in front and 1" in the back. I was told at an off road shop that 265/75/16 will hit upper control arm, any truth to that or is this a " buy more stuff to make it work" pitch, I have a 2011 Prerunner TRD Off-Road.
  11. Jul 5, 2012 at 11:00 AM
    KPT
    09 Prerunner
    It will clear the uca fine.
  12. Jul 6, 2012 at 6:54 AM
    Retiredlinetrash
    Plug
    Ca
    That otta do it. Thx for the info. I'm a new guy on the block & and this site is very helpful. Thx again.
