285/70/17 do fit with a 2 inch lift
Discussion in 'Wheels & Tires' started by RespectTheTaco, Sep 11, 2017.
  1. Oct 30, 2018 at 10:45 AM
    #81
    Willtaco
    Willtaco I Love Tacos!!
    Will
    SoCal LA
    18 Tacoma TRD OR 4x4 DC/SB
    •Xenon LED lights •EGR channel window visor/Hood Protector •total chaos bed stiffener •TRD cold air intake. •30” Rough country light bar •King’s suspension and springs •Camburg UCA/ replaced with JBA UCA •Method wheels •285/70/R17 Falcon wildpeak •slimeline bumper •All pro rock sliders •All pro skid plate •winch Plus a few more goodies and That’s all I have to say about that..
    I have my tires out for delivery Shown on photo, I hope I don’t have much rubbing... :rolleyes:
    TacoPandaTRD, Hooper89, Guy27 and 2 others like this.
  2. Nov 19, 2018 at 3:25 PM
    #82
    tkwny
    tkwny Well-Known Member
    Randy
    Wylie, TX
    2016 Quicksand Tacoma TRD Off-Road
    Toytec 3" Lift w/AAL Demello Hybrid Sliders BFG KO2 285/70/17
    I'm running 285/70/17 KO2s with a 3" lift (also leveled the front out so I'm probably close to 4" up there). No rubbing issues for me off-road. Before the lift went on I couldn't even get in the driveway without it sounding like I was leaving something behind. Curious to see how the 2" does under load up front.
  3. Dec 17, 2018 at 10:20 PM
    #83
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    2” lift & ko2’s mine rub
  4. Dec 18, 2018 at 7:26 AM
    #84
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    Wheel specs would help.
  5. Dec 19, 2018 at 12:17 PM
    #85
    508Tacoma
    508Tacoma Well-Known Member
    MA
    2017 TRD OR 4x4 DCSB
    hahaha me right now
  6. Dec 19, 2018 at 12:49 PM
    #86
    The1youluv2hate
    Peps
    SAnta Paula CA
    17x8 0 offset
  7. Jan 8, 2019 at 3:52 AM
    #87
    slowyellow
    slowyellow Active Member
    Geoff
    Virginia Beach, VA
    2017 Tacoma Sport
    None
    Well, I'll keep this thread alive. I'm about to put on a Icon Stage 4 lift with some Method 701 wheels (17x8.5, 4.75" backspace, 0 offset) with 285/70r17 BFG's with the C load range. Hoping that it won't rub, not sure if I'm going to need to do a CMC? I'll update once everything is on. Any thoughts are appreciated, and if anyone knows someone in the Va Beach area that could help with the CMC, that advice would be appreciated.
  8. Feb 21, 2019 at 9:52 PM
    #88
    lilcez3
    lilcez3 Well-Known Member
    None yet
    I'm just going to throw this comment in the air & see if someone can shed any knowledge. Planning to run Falken 285-70-17 on SCS F5 wheels 17 x 8.5 -10 Offset 4.30 BS.
    Cab mount chop will be done along with pinch weld. Will I rub anywhere?
  9. Feb 22, 2019 at 7:30 AM
    #89
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    front bumper
  10. Feb 22, 2019 at 8:41 AM
    #90
    lilcez3
    None yet
    Would I need to trim? Or simply hammering things out of the way? I guess I'll find out lol
  11. Feb 22, 2019 at 9:11 AM
    #91
    commbubba19
    '23 TRD PRO
    likely push the liner in and re-secure it plus trim the bottom of the bumper. the more you lift, the less it's an issue but once you flex you'll be right into the bumper.
  12. Mar 25, 2019 at 12:39 PM
    #92
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Bumping this so others can read nd get an idea. I'm running 285/75/16 -10mm @ 4.0BS stock suspension they rub hard on all the plastic stuff. You will need a CMC for sure and smash your pinch weld to run this tire size of you plan to use your truck off road.
    Clearance on the the stock UCA is 3 1/4"with the back spacing.
  13. May 28, 2019 at 10:02 AM
    #93
    4x4?lol
    4x4?lol @az_greenery
    James
    Arizona
    2008 Silver PreRunner
    Fox 2.5 w/resi all around, rears tuned from accutune with their larger shock body (1.5"-3" lift), Icon delta joints, OME Dakar medium leaf's, wheelers super bumps, fab fours rear bumper. Lifted 3" in the front and about 2.5" in the rear on some Pro Comp La Paz 17x8.5 wrapped in 285/70 Pro Comp A/T Sport's. SOON TO COME: Lowering front about 1" New tires Rear diff lock Nfab RSP front bumper and some lights
    I know im a bit late but did you ever get em on?
    Greg.Brakes.Tacos likes this.
  14. May 28, 2019 at 3:10 PM
    #94
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    here's my 285/70 on SCS S6 17x8.5 (4.30 bs and -10mm offset) I have a few large and deep pot holes on my road, so though not anywhere near full flex, I went ahead and checked full right and left clearance for $hits and giggles...20190528_171537.jpg 20190528_171517.jpg
    CMC totally due here soon, now just shooting for more flex/stuffing rub detecting, ahead CMC and pinch weld work. 20190528_165344.jpg 20190528_165408.jpg20190528_165403.jpg just clearing CM, back well liner.
    rear tire clearance with 1in block on stock suspension. 20190528_171400.jpg My medium range plan (we are expecting 1st baby Dec. 2019) is to remove spacer/block for suspension lift (likely 5100s ome888 or 887, Dakar medium leaf pack [figured better option for trailering wood rounds for firewood] and LR UCAs).
    FJ to Taco, angerbot and Bascoma like this.
  15. Jun 30, 2019 at 10:53 AM
    #95
    tacoooking
    tacoooking Well-Known Member
    Dana Point, CA
    2016 TRD Off-Road
    i lifted 2.5 in the front and still needed a CMC
  16. Jun 30, 2019 at 8:54 PM
    #96
    4x4?lol
    James
    Arizona
    How is it now with the CMC? ever rub in full lock or anything?
  17. Aug 28, 2019 at 1:30 PM
    #97
    Joe671
    Joe671 YouTube Mechanic
    Joe
    Washington State
    2019 Tacoma TRD Off Road
    Did you ever get this done? Found a deal on Method Grid wheels with same specs and was wondering how much trimming you had to do with the 285/70R17's.
  18. Sep 9, 2019 at 9:37 AM
    #98
    wheelin fun
    wheelin fun Active Member
    2017 Tacoma 4x4 Sport
    Howdy all, I have 2017 Tacoma TRD sport 4x4 with stock wheels and spidertrax 1.25 spacers. Bilstien 5100 at 3rd clip. Milestar Patagonia 208/70/17. Initial rub at passenger full lock on right turn. I removed the mud flaps and no more rubbing.
    I also uploaded a video to my youtube channel for better viewing
    https://www.youtube.com/channel/UCtWFbndNYpGgfSw9VUWj5sA
    Hope this helps
    xola3que likes this.
  19. Oct 27, 2019 at 8:31 PM
    #99
    Chris_TRDTaco
    Chris_TRDTaco Member
    ‘04 TRD OR Prerunner, ‘23 TRD OR 4x4
    TRD Supercharger/ 5100’s/ 16x8 wheels/ 265/75/16 KO2’s
    Finally I found a wheel with the exact specs I have. I’m trying to see if I can fit 275/70/17 on just a 2 inch front lift and could find anything. Looking at this now I should be fine! Thanks !
  20. Mar 14, 2021 at 10:02 PM
    #100
    tbib
    tbib New Member
    Tom
    Taco
    Will I have any issues running 285x70x17 K02 with 17 Inch 6 on 5.5 wheels. Raising it 3” w/ OLD MAN EMU SUSPENSION KIT.
