285/70/17 tires
Discussion in '4 Cylinder' started by 2012TacoToy, Feb 19, 2012.
  1. Feb 19, 2012 at 5:09 PM
    2012TacoToy
    2012TacoToy [OP] Member
    Ohio
    2012 Tacoma 2.7l 4x4
    3in lift
    Would running a 285/70/17 all terrain on a 17x9 rim be to big for my truck it's a 2012 reg cab with a 3in lift would it rub if so how bad? Or do you all have any other suggestions of a rim tire size combo? Thanks any help would be appreciated
  2. Feb 19, 2012 at 8:21 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    I have pro comp 17 x 9, 4.5" back spacing, I can't remember the off set and 285 70 17 km2's. I have the ultimate lift set at just above 3" and I had to cab mount chop, pinch weld mod to get rid of all the rub at full droop, turn radius in both directions and flexed out to the max. Also note that I removed my mud flaps. If your staying with stock bumper you will need to trim there also.
  3. Feb 22, 2012 at 1:10 PM
    Doooh77
    Doooh77 Member
    Ma
    Black Tacoma trd
    Toytec ultimate lift, tc uca's, all pro exp leafs, K&n intake, nfab steps,magnaflow dual exhaust, tonneau cover, grillcraft grill, pioneer z1 head unit with custom kickers behind rear seats, kicker zx750 mono amp, all around Alpine speakers, remote start alarm.
    I have an 11, 3 inch lift with 1 inch spacer, just put the 285 nitto's on, and all that rubs a little is that little nub water catcher plastic thing right in front of front tires, little trim, no cab mount or anything
  4. Feb 22, 2012 at 4:31 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    spider trax spacer. I smell a re-gear with this size tire on a 2.7
  5. Feb 26, 2012 at 7:31 PM
    hamsterhater
    hamsterhater Well-Known Member
    long island
    11' dc mag grey taco
    level kit- exhaust -cai n-fab light bar-4 piaa 6"new hood w/scoop
    :ohsnap:
  6. Feb 27, 2012 at 3:32 AM
    Doooh77
    Doooh77 Member
    Ma
    Black Tacoma trd
    It's a 4.0
  7. Feb 27, 2012 at 6:02 AM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    I had to trim but now no rubbing...
  8. Feb 28, 2012 at 3:38 AM
    Doooh77
    Doooh77 Member
    Ma
    Black Tacoma trd
    I talked to soon, didn't have to back up for a few days after tire install, but that's where it rubbed, when I went in reverse and had it cut all the way, just had to trim about half an inch on both sides of the front bumper right at the corner in front of front wheels, but that was it. No major cutting, trimming or cab mount chop.
