285/70/17s on 17x9 Motos with 2.5" Lift
Discussion in 'Wheels & Tires' started by BradleyJ33, Jul 23, 2009.
  1. Jul 23, 2009 at 6:24 PM
    BradleyJ33
    BradleyJ33 [OP] Geaux Tigers
    Brad
    Brandon, MS
    2010 TRD Sport 4x4 DCSB S/C'd
    TRD Supercharger with URD 2.825" Pulley, Toytec Ultimate Lift, LR UCAs, BFG All Terrain 275/70R17s on Procomp 7089 17" wheels, BAMF rock sliders, Viper 5902 alarm/remote start with smartstart, Pioneer Avic-Z110BT dvd/navi head unit, 2 Pioneer 7" monitors in headrests, 2 Rockford Fosgate Shallow-mount 10" subs pushed by RF Punch 500.2 amp, RF 5.25 components (front doors) and 5.25 full range (back doors) pushed by RF Power 400.4 amp, sound deadened, Whistler pro remote radar detector, scangauge II, debadged, Sockmonkey decals, blacked headlights with FX-R projectors, DDM Tuning HID fogs, Grillcraft upper and lower MX grill with Hella 500ffs converted to HIDs behind, AFE Stage 2 Cold Air Intake, Walbro 255 Fuel Pump upgrade, Dynomax Super Turbo muffler, Bestop Supertop, Wet Okole seat covers, Weathertech floor liners, Pop & Lock tailgate handle, Lighted 4x4 switch mod, 2 110v AC outlets in cab mod, Always at 400W mod, Maplights on with dome light mod, homelink in headliner mod, foglight
    Ok, so I've searched, and still trying to get a definitive answer. Sorry for posting something that's probably been beaten to death. I'm planning on putting 285/70/17 Cooper Discoverer STTs on 17x9 MotoMetal 955s on my 2010 Taco with Bilstein 5100s set at 2.5" in the front and Toytec 1.5" AALs in the rear. Will this setup rub without spacers, and if so, how bad? And if it would rub, would spacers (and what size) fix the problem? Thanks in advance for answering a question that I'm sure has been answered before! :D
  2. Jul 23, 2009 at 8:10 PM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    You'll be good. Just need to trim the front wells.
  3. Jul 23, 2009 at 8:13 PM
    BradleyJ33
    Brad
    Brandon, MS
    Would spacers eliminate the need to trim the wheel wells, or do I have to trim regardless? Thanks for the reply!
  4. Jul 23, 2009 at 8:16 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    It would but make sure you get spydertrax if you do decide to run spacers, 1.25" should be plenty :)
  5. Jul 23, 2009 at 8:19 PM
    Padilla1880
    Daniel
    Temecula, CA
    Are you running spacers for a wider stance?
    Don't have experience with spacers, but yes i think you would still have to trim.
  6. Jul 23, 2009 at 8:21 PM
    BradleyJ33
    Brad
    Brandon, MS
    Well I like the look of the wider stance, but I think I would get a little wider with the 17x9 motos already. I was just gonna add them if they would eliminate the need to cut on the truck mainly...I may still add them anyway even if I'd have to cut either way, just depends on the way it looks without them...
  7. Jul 23, 2009 at 8:29 PM
    Padilla1880
    Daniel
    Temecula, CA
    4.5 backspace right?
  8. Jul 23, 2009 at 8:32 PM
    BradleyJ33
    Brad
    Brandon, MS
    Yeah, website says 4.53...
  9. Jul 23, 2009 at 8:35 PM
    Padilla1880
    Daniel
    Temecula, CA
  10. Jul 23, 2009 at 8:37 PM
    BradleyJ33
    Brad
    Brandon, MS
    Ok I appreciate it!
  11. Jul 23, 2009 at 8:39 PM
    Padilla1880
    Daniel
    Temecula, CA
    Post some pics up when you get it done!
  12. Jul 23, 2009 at 8:40 PM
    BradleyJ33
    Brad
    Brandon, MS
    Definitely will. I'm still a little ways from it, but tryin to get everything researched so I know exactly how much I need to save up and all. Looking forward to having my own build thread!
  13. Jul 23, 2009 at 8:41 PM
    Padilla1880
    Daniel
    Temecula, CA
  14. Aug 24, 2009 at 11:07 PM
    StaticTaco
    StaticTaco 2 is 1, 1 is none.
    Mitch
    Oahu
    2011 SR5 4WD
    reviving thread instead of making a new one since my question pretty much relates. my trucks lifted with 5100s at 2.5" but has a 1" block at the back. im just curious if my rim and tire combo will work, my rims offset is -8 and the back spacing is 4.625. and i'd like to run 285/70 mickey thompson baja mtzs.
    will i run into any problems? i intend on trimming the wells. thanks!
  15. Aug 26, 2009 at 7:21 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    Talking to some people at a local shop they told me the mtz's rubbed the least from thier experiance because the tread on them isn't very big on the sides of the tire. If you have trouble understanding what I'm trying to say compare pictures of them to the nitto terra grapplers. It seems 4.5 is the golden rule and that will even require some wheel well trimming, I don't know for sure about that extra tenth of an inch, but there's a few guys on here that run mtz's, if they dont chime in just search around for them.
  16. Aug 26, 2009 at 7:33 PM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    Can you even get the Cooper stt's in 285/70/17??? I thought the new version with the tek3 didn't come in that size, only the older version did? Or are you buying the older version of them?
  17. Aug 26, 2009 at 11:24 PM
    StaticTaco
    Mitch
    Oahu
    2011 SR5 4WD
    I just decided to go with the mtz because they look aggressive but not to the point of swampers, never thought that the tread would be slightly smaller than other m/ts. Interesting... Might be able to get away with the 4.625 backspacing. If anything I'm not totally against going with their atz tire. Guess this is going to be hit or miss.
    Thanks for the info, I'll continue digging.
