285/70-17's vs. 305/65-17's ... rubbing and trimming ...
Discussion in 'Wheels & Tires' started by Randy1, May 22, 2009.
  1. May 22, 2009 at 12:17 PM
    Randy1
    Randy1 [OP] New Member
    2007 Tacoma TRD Access Cab 4x4 ... with a 3" suspension lift.
    Have ordered Pro Comp 6001 17" x 9" wheels that have a -6.6 offset ... according to the tire calculators the tire/wheel package will stick out 2.2" or 2.4" further than stock (285 vs. 305).
    My delema is which tire size to go with ... 285/70 or 305/65 ...
    As far as I know the 285's will work just fine with minimal or no trimming/rubbing but I have heard that if one goes with the 305/65's there are a lot of rubbing issues and lots of trimming to do ... is that true?
    Remember, I have a 3" suspension lift, maybe that makes a difference.
    I want to go with the 305/65's but don't want a bunch of trimming or rubbing.
    Your comments? Experiences? Suggestions? Pix?
    Thanks,
    RB
  2. May 22, 2009 at 12:24 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    305's are gonna be too big.
    285 is the biggest you'll wanna go with a 3" lift
    im running 285-65s and I have rubbing on the frame when I go over dips and shit when turning
  3. May 22, 2009 at 12:27 PM
    ToyoComp
    ToyoComp Addicted Mod'r
    Tampa, FL
    07 4x4 TRD Off Road DC
    Sway-A-Way Race Runner 2.5 coil over (3" lift) & 2.0 rear shocks on TSB springs, Total Chaos UCA, ToyTec differential drop, 8128 Pro Comp wheels, Toyo Open Country RT 285/70/17, DT Long Tube headers, TRD CAI & exhaust, Line-X coated Famous Fabrication front bumper, Demello Sliders and rear bumper, Wet Okole covers, Rigid LED spot & fog, bed mat, debadged & TRD brake pads
    I wouldn't recommend the 305's and I can tell you that even the 285's can rub the plastic wheel well liners depending on the offset. I also have a 3" lift and with full lock turn and suspension compression could cause rubbing without minor trimming.
  4. May 22, 2009 at 1:18 PM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    Do not do it unless u have at least 4" of lift. You will have serious rubbing issues
