285/70R17? with 5100 @2.5 and 17" stockers??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Scarab21, May 31, 2010.
  1. May 31, 2010 at 7:16 PM
    Scarab21
    Scarab21 [OP] Well-Known Member
    Tint, tinted tails + 3rd brake light, shaved tailgate, painted calipers. TSB Leafs+ AAL, PA/CB, 5100 Bilsteins set @ 2.5 up front. Satoshi line-x'd grill.
    Ok i think ive asked this before but a lil different.
    Can I fit 285/70R17 BFG Mud Terrains on my tacoma sport with 5100's @2.5 on STOCK rims?
    will they fit the stock 17" rim?
    will they rub a lot?
    Do i need a spacer?
  2. May 31, 2010 at 7:18 PM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    I don't think you can. The backspacking of a stock wheel is too high and would cause rubbing against the UCA. Maybe a wheel spacer would be good.
  3. May 31, 2010 at 9:40 PM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    offset will not be right, you will get rub on the upper control arm.
  4. May 31, 2010 at 9:53 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    1/4 inch wheel spacer did it for me. i had the trd sport rims 285/70/17 nitto terra grapplers i had that at stock height rubbed a little rubbed more when i lifted it but i lived with it didnt bother me
  5. May 31, 2010 at 10:43 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    They'll fit but def rub your UCAs. You need wheel spacers to keep the stock wheels, or an aftermarket UCA might allow enough clearance without spacers.
  6. Jun 2, 2010 at 7:21 AM
    Scarab21
    i hear bad things about wheel spacers.. im guessing id need about an inch.. is this correct?
    anyone else wanna chime in?
  7. Jun 2, 2010 at 7:25 AM
    jacob_wood
    jacob_wood Well-Known Member
    Jacob
    Boulder Creek, CA (Nor-Cal)
    2010 SSM DCLB
    What bad things about wheel spacers?
  8. Jun 2, 2010 at 7:28 AM
    Scarab21
    ive done some research and some people seem to think they break.. while offroading.. ppl say.. DONT OFF ROAD WITH IT.. but i dont see there being that serious of a problem,, but what the hell do i know?
  9. Jun 2, 2010 at 11:15 AM
    Scarab21
    anyone know if spacers are Ok for offroading? and what size i should get?
  10. Jun 2, 2010 at 11:42 AM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    I got myself a full set of Spidertrax spacers. I've been told if you get any, get the good ones.
    Spidertrax are the de-facto recommendation for anyone asking about spacers. $100 for two. They add 1.25".
    Just installed them. See gallery for pics of the subtle change in appearance. I'm building up my truck to get to the same tires: BFG AT 285/70R17
    Next stop: Also going to get the Toy ultimate lift this month, and when I paid off my cc I'll get the tires too.
