285/75/16 with a 2 inch level?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Frank_Tank, Nov 15, 2023.
  1. Nov 20, 2023 at 7:25 PM
    kas2828
    kas2828 Well-Known Member
    Austin
    Arizona
    2020 TRD Off-road 4x4 DCLB
    Did you get the rubbing figured out? Some slight trimming might be needed but hopefully the rubbing isn’t that bad for you.
    Yota_MGM likes this.
  2. Nov 20, 2023 at 8:41 PM
    kas2828
    Austin
    Arizona
    You might be able to use a hammer and push back the fender liner. I’m surprised you have that much rubbing. Also look into an alignment to help. I’m running a -6 offset with same size tires and take it off roading on the weekends and don’t rub unless hitting something hard. How bad are your rubbing? On bumps? Or all the time?
    Yota_MGM[QUOTED] likes this.
  3. Nov 20, 2023 at 8:59 PM
    kas2828
    Austin
    Arizona
    Try taking a rubber mallet to that area and see if you can smash it back a little. I think it will help stop the rubbing. The UCAs are nice but I think you could get away without them if trying to save some money.
  4. Nov 21, 2023 at 5:54 AM
    RobotTheDog
    RobotTheDog Well-Known Member
    AZ
    21 TRD OR DCSB CEMENT
    All encompassing layer of dust
    The SPCs are awesome. The camber/caster adjustability can't be beat. You just need someone who knows how they work, most shops won't touch them, only making adjustments through the LCA cams.
  5. Nov 21, 2023 at 6:13 AM
    WELLSPRING
    WELLSPRING Well-Known Member
    Ted
    Asheville, NC
    2020 TRD Off Road DCLB
    Leer 100XR cap, Total Chaos bed stiffners, OEM PRO Intake Flow Accelerator, Bed Mat
    Who makes your bumper, and what did you do for front suspension to take into account that extra weight? Love the look as I too have a DCLB. Thanks
    kas2828 and cmonjack like this.
  6. Dec 8, 2023 at 9:57 AM
    Danner488
    Danner488 Well-Known Member
    2016 TRD Sport
    Nice looking set up.
    I smacked a deer and one of the things I need will be a new bumper and the BA with wings is at the top of my list.
    Are those lights on the wings or just reflectors? If they are functioning lights, where do they luminate? The wings look like they point the light down and outwards.
    I've got DD Max fogs so I don't necessary need more front lighting. I'm pondering amber, white or saving money and just a filler piece in the wings depending on how functional the lighting is.
  7. Dec 8, 2023 at 4:39 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    285/75/16 Yokohama G003’s with a 2” level in the front:
    TaCosmere, Millertaco21, Xero and 3 others like this.
  8. Dec 9, 2023 at 6:20 PM
    Danner488
    2016 TRD Sport
    Thanks for the reply.
    I was mainly wondering where the wings point the light. Like if I got a spotlight would the beam be focused to close and low. Would a flood pattern project like a ditch light.
    The lights if they happen will be sometime after the bumper. I like the look without the wing holes so I was considering using some black 1/8” thick uhmwpe for the interim.
