285-75-16????
Discussion in 'Wheels & Tires' started by freezb, Oct 14, 2010.
  1. Oct 14, 2010 at 11:24 AM
    freezb
    freezb [OP] Active Member
    montreal
    tacoma trd 2011
    roof rack toyota side step toyota
    Im loocking to buy a tacoma 2011 and i notice that the original tire sizes is 265-75-16, so how you do to put 285-75-16??? It's not to big? and the speedo ??? and the differential??
    Scuse for my english im from montreal quebec. thank'S
  2. Oct 14, 2010 at 11:26 AM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    265/75 is not stock tires. 285s will fit, you will need spacers, a bit of trimming, and a small lift to ride them comfortably. the speedo will be off, mine is about 2-3mph slow. differential is fine.
  3. Oct 14, 2010 at 11:29 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    The stock tire is a 265/70/R16, i think about a 3 MPH dif and your gearing will be fine.
  4. Oct 14, 2010 at 12:18 PM
    freezb
    montreal
    tacoma trd 2011
    But here in my catalogue of the tacoma 2010 they said
    245-75-16 for the access and the doubble cab, after with the SR5 package is 265-70-16 and the TRD have the 265-75-17
  5. Oct 14, 2010 at 12:19 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You will need to have a 3" lift, spidertrax wheel spacers (or aftermarket wheels with 4.5" backspacing), trim plastic, and possibly chop the cab mount to fit 33's without rubbing.
  6. Oct 14, 2010 at 12:19 PM
    KPT
    09 Prerunner
    That's incorrect.
    SR5 has 245/75/16
    TRD offroad has 265/70/16
    TRD sport has 265/65/17.
  7. Oct 14, 2010 at 12:27 PM
    freezb
    montreal
    tacoma trd 2011
    scuse me yes your right! ok but if you go with 285 you will need to go with 65 of heigh. and not 75??
  8. Oct 14, 2010 at 12:28 PM
    KPT
    09 Prerunner
    Depends on the rim size.
    Tire Size calculator
  9. Oct 14, 2010 at 12:33 PM
    freezb
    montreal
    tacoma trd 2011
    exact, 265-75-16 to 285-75-16 is no good, but 285-65-16 is ok.
    So if i put the TRD wheels the one like the FJ, 16-7 i think, what will be the best sizes of tires on a stock suspension???
  10. Oct 14, 2010 at 12:39 PM
    KPT
    09 Prerunner
    265/75/16 will be the biggest you can fit on stock suspension. I think you need the lift for the 285's, even if they are not 33's. I've never heard of anyone running 285/65/16's.
