285/75/R16 Owners Experience
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Danimal69361, Sep 21, 2013.
  1. Mar 6, 2014 at 12:34 PM
    AlanLoshbaugh
    AlanLoshbaugh Well-Known Member
    Alan
    Columbia, MO
    2013 Tacoma Double Cab 4x4
    Thanks for that!
    My 2006 had a 2" Ironman lift and Toyota ''Baja'' wheels.
    The 2013 will have the same lift, and has the factory issue SR5 trim wheels.
  2. Mar 6, 2014 at 2:40 PM
    tomwilson74
    tomwilson74 Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
    I have an OME lift and stock Toyota steelies. I want to put 285/75/16's on but I'm sure they are gonna rub the UCA's. It's very close right now with 265/75/16's on.
  3. Mar 6, 2014 at 2:47 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I'll play.
    285/75/16 Goodyear MTR K's
    Konig Countersteers
    0mm offset
    4.5 backspacing
    8" wide wheel
    stock UCA
    good alignment and small rubbing at stuff and lock to lock.
    No cab mount chop.
    I'd say I wheel fairly hard.
  4. Mar 10, 2014 at 12:03 AM
    Biznitch15
    Biznitch15 Well-Known Member
    José
    Los Angeles/San Diego
    13 DCLB TRD Sport
    None Yet
    You think having like -12mm offset would solve the rubbing problem?
  5. Mar 10, 2014 at 8:23 AM
    SconnieHailer
    Marc
    Hey Jose, im not sure if it would totally cure the rubbing but it would help. I think no matter what you're going to have some rubbing somewhere with 285's. If all you do is street driving then you might be fine with no trimming.
  6. Mar 10, 2014 at 8:29 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    I run 285/75/16's on stock steelies with a 1.25 spidertrax, I chopped the cab mount and moved some plastic around at the front of the wheel well and have gotten to a point that I never rub at all. 2.5 inches of lift in the front.
  7. Mar 19, 2014 at 8:52 PM
    Biznitch15
    José
    13 DCLB TRD Sport
    None Yet
    Marc, thanks. I definitely Plan to wheel off road, but the thing that concerns me the most is the Tire Rub. I plan on:
    ICON Stage 5 (SDHQ) 2-3''
    Fuel D517 Krank Wheels (17X9) -12 offset
    Toyo Open Country MT 285/70/17
    I just dont want to Chop anything. But i guess if i have to then i will. But if its gonna be too intrusive then I might just stick with 265's
  8. Mar 19, 2014 at 9:03 PM
    SconnieHailer
    Marc
    with a -12 you're going to likely get into the fender, at least i do with superbumps in the front and a 0 offset wheel.
  9. Mar 20, 2014 at 12:13 AM
    AlanLoshbaugh
    Alan
    Columbia, MO
    285/70 is gonna be almost the same height as 265/75
    Though it will be wider.
  10. Mar 21, 2014 at 3:42 AM
    Biznitch15
    José
    13 DCLB TRD Sport
    None Yet
    Yeah. I'm definitely looking at a more wider configuration.
  11. Mar 21, 2014 at 9:36 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I have 285/75/16 Dakota Definity MT's on stock SR5 steel wheels. Front lift is Blstn 5100 at lowest setting, OME 886x springs and 1/4" top spacer. Also have LR UCA's. Only trimming I did was cut out the front water nipple in the wheel well and remove the front mud flaps. Without wheel spacers I don't rub, but am super close to the UCA, like half of a pinky, and with the spacers, I don't rub either. I mainly use the wheel spacers for a more agressive stance. I also keep the tires inflated to 35 psi. Even off road, I may have touched the fender twice.
  12. Mar 22, 2014 at 5:34 AM
    Biznitch15
    José
    13 DCLB TRD Sport
    None Yet
    I haven't really thought about this. I hope you guys can answer. Does having 285's go against any wheel travel you might gain from a coil over lift?
  13. Mar 22, 2014 at 7:12 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    No
  14. Feb 13, 2015 at 1:35 PM
    msoverland
    msoverland Mountain State Overland
    Appalachia
    2020 Tacoma DCSB
    Expedition Equipped
    So neither one of you guys had to do any cutting and both of you are running 2012/2013 models - hmmmm....
    I'm on a 2013 DCSB OR platform with OME 886, LR UCAs and Dakars. I'm really thinking 285s will work on the OR rims. Any comments?
    I'm running 255s now, just running out of options for replacements...
  15. Feb 13, 2015 at 1:45 PM
    #35
    AlanLoshbaugh
    Alan
    Columbia, MO
    I went with 265's as I was concerned about 285's wanting a re-gear.
    The 265's haven't rubbed, and I'd wager based on how I've used mine, the diff from 265 to 285 wouldn't be a problem.
    I think the TRD rims widen the wheelbase 1" on each side, IIRC, which I may not.
    I'm on an Ironman ~2" lift with stock UCA's.
  16. Feb 13, 2015 at 1:47 PM
    #36
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I'm running 285/75/16s with 3" lift...
    My wheels are 4.5" back spaced and my cab mounts are chopped...I also had to trim a little on the inside fender. I have an off road front bumper so no rubbing there.
  17. Feb 13, 2015 at 1:49 PM
    #37
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Expedition Overland ran 285 Generals with a 3" Icon lift on the stock TRD OR Rims. They mentioned minor rubbing on the UCA but were able to make it work. Not sure what type of other stuff they did like CMC, pinch weld, and fenders. I know that with my stock base steel wheels there was no way I could even get close to fitting the tires without spacers. The tires hit the UCA before I could even get the lug nuts on and last I check my alignment specs were in good order.
  18. Feb 13, 2015 at 1:54 PM
    #38
    msoverland
    Appalachia
    2020 Tacoma DCSB
    Expedition Equipped
    Thanks Alan; great info. I lost a bit of power on my 255s w/o a regear but it wasn't a huge concern.
    It's really starting to sound like 2012-2014 Tacomas with OR wheels and 2-3" are good to go without much of any body chopping/shaping.
    Anyone else have some thoughts?
  19. Feb 13, 2015 at 1:56 PM
    #39
    AlanLoshbaugh
    Alan
    Columbia, MO
    I didn't even take the front mini-flaps off....fwiw.
    ou can get those wheels for ~$150-ish per on ebay. Which I took to my dealer, and they matched...I've done biz with them for 30 years tho...and I do their tv commercials.
    #39
  20. Feb 13, 2015 at 1:59 PM
    #40
    msoverland
    Appalachia
    2020 Tacoma DCSB
    Expedition Equipped
    Yeah I read that too. I've got the LR UCAs and I'm really thinking it all work out. Surely there has to be someone on TW with the OME, OR wheels and LR UCAs that can chime in and solve this mystery!?
