285/75-R16 vs 305/70-R16
Discussion in 'Wheels & Tires' started by TacoTy, Jun 17, 2014.
  1. Jun 17, 2014 at 8:38 AM
    TacoTy
    TacoTy [OP] Active Member
    Ty
    Colorado Springs, CO.
    2012 Tacoma
    So doing a little research on tires and have been going more towards the 285's, but I found a tire I may be interested in and the closest they make to that size is the 305's. I used the tire calculator with these results -
    http://www.tacomaworld.com/forum/tirecalc.php?tires=285-75r16-305-70r16
    So I have done extensive reading here about how the 285's may or may not rub with a 3 inch lift, which is what I will be putting on. I guess my question is, is it the width of the tire that causes the rubbing or the height?
    What kind of trouble may I run into with a 3 inch lift and putting the 305's on?
    Thank you very much!
  2. Jun 17, 2014 at 8:49 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    It's a combination of a lot of things that causes rub. Can be diameter and height, and also wheel specs. All effect it and can cause rub in different ways and places, theres no one exact answer.
    But generally, a wider tire is more likely to rub when turning due to the extra width. Rubbing UCA is possible with too much back space/too little offset, and the flip side is too little back space/too much negative offset will cause the tire to 'scrub' more when turning and rub cab mount as well as possibly frame rail at full lock(frame rub is more of a 1st gen tacoma thing though)
  3. Jun 17, 2014 at 8:54 AM
    TacoTy
    Ty
    2012 Tacoma
    Thank you very much for a quick answer.
    So what is the best way to figure this out? Go to the store and have them mount the tires and test it out? (can you even do this?)
  4. Jun 17, 2014 at 9:33 AM
    RelentlessFab
    Eric
    Sparks, NV
    which wheels are you looking at. I can give you a good idea of what to expect just by knowing which wheels you plan to go with
  5. Jun 17, 2014 at 9:50 AM
    TacoTy
    Ty
    2012 Tacoma
  6. Jun 17, 2014 at 10:03 AM
    RelentlessFab
    Eric
    Sparks, NV
    Ok but which wheels? You'll need aftermarket wheels for those tires regardless of which ones you choose
  7. Jun 17, 2014 at 10:30 AM
    TacoTy
    Ty
    2012 Tacoma
  8. Aug 4, 2014 at 8:31 PM
    ProPhaze777
    ProPhaze777 Well-Known Member
    Yakima,wa
    '14 trd offroad black
    Bump for more info on 305s, in the market right now. What lift should be attained in the rear and with what?! Maybe Ome full kit with Dakar in the rear?
